[fdo-users] Is there a Feature class naming convention
Traian Stanev
traian.stanev at autodesk.com
Wed Jan 23 09:40:18 EST 2008
Yes. The only reason King and PostGIS have this problem is because some of their code was based on the OGR provider, not because of some convention. They don't really have to do the name translation since they can make assumptions about the underlying database. You can enter a Trac ticket for that, if you haven't done so already.
Traian
________________________________________
From: fdo-users-bounces at lists.osgeo.org [fdo-users-bounces at lists.osgeo.org] On Behalf Of Bruno Scott [bscott at geomapgis.com]
Sent: Wednesday, January 23, 2008 8:50 AM
To: fdo-users at lists.osgeo.org
Subject: RE: [fdo-users] Is there a Feature class naming convention
Specifically for the PostGIS provider
we specify the connection string with
Service : MyDatabase at host:port
Datastore : MySchema
So i think the featureclass name could only be "MyTable" instead of
"MySchema~MyTable"
Because we have already the datastore/Schema in the connection string
Am i right?
Bruno
Bruno Scott wrote:
> Let me explain my problem.
> We have developped a huge application that does lot of specific industry
> task.
> These industry are Transportation,Cadaster,Facility management,Telco and
> so on.
> We historically used 2 driver to access and Maintain all these data :
> OleDb and OCI
> We have recently added support to FDO
> The same application could run on Access,SqlServer,Oracle,MySql.... with
> the same setting (table name, column name...) only the connection string
> change.
> To make sure that everything works fine we do unit testing on each of
> these databases.
> Symmary of the steps involved in unit testing
> drop all the tables
> Create all the tables
> fill all the tables with known values
> Launch some specific industry fonction
> Test if the function did the right thing
> A specific industry function consist of one or many of these:
> Select some record
> Insert some record
> Delete some record
> Update some record
> The only things the application knows to acheive this are
> a connection string to the database
> a table name with optionnaly a schema name
> the column names
> This end up with something like this
> Drop table "MyTable"...
> Create table "MyTable"...
> Insert into "MyTable"...
> These sequence of statement work fine on Most fdo provider
> Autodesk.Oracle
> Autodesk.SqlServer
> Osgeo.MySQL
> Osgeo.SDF
> Osgeo.SHP
> I have problems with Osgeo.PostGIS,
> with PostGIS i have to do that to make it working
> Insert into "MySchema~MyTable"...
> How i am suppose to know that the featureclass name should be
> "MySchema~MyTable" instead of "MyTable"
> I wish FDO had a method like GetPhysicalName who would return
> "MySchema.MyTable"
> So i would be able to map featureclassName to physical table name
> automatically
> Bruno
> JasonBirch wrote:
>> I believe that the PostGIS provider only implements the native PostGIS
>> data access, and has no way of storing FDO-specific logical/physical
>> mappings (not sure if I have the right terminology here). I believe
>> that the second scenario would require the PostGIS provider to implement
>> some way of persisting this information?
>> Jason
>> -----Original Message-----
>> From: Orest Halustchak
>> If the provider is accessing an existing schema, e.g. not created by
>> fdo, then the provider decides how to map the table / file to a class
>> and schema. The main thing is that the mapping is unique and unambiguous
>> as Traian said.
>> The other scenario is if a new class is defined via fdo. In this case,
>> the caller is specifying an explicit schema name and class name. A
>> describe of that class then should come back with the same names as long
>> as the input names were valid (FdoISchemaCapabilities has methods to get
>> information about valid names such as name size limits and valid
>> characters).
>> fdo-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/fdo-users
View this message in context: http://www.nabble.com/Is-there-a-Feature-class-naming-convention-tp15021175s18162p15042014.html
Sent from the fdo-users mailing list archive at Nabble.com.
More information about the fdo-users
