[fdo-users] dgn provider
Traian Stanev
traian.stanev at autodesk.com
Fri Jan 25 16:36:50 EST 2008
A good way to see if the OGR provider is working at all is to try to connect to an SHP file. Does that work for you?
Traian
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-
> bounces at lists.osgeo.org] On Behalf Of Brad Nesom
> Sent: Friday, January 25, 2008 4:27 PM
> To: 'FDO Users Mail List'
> Subject: RE: [fdo-users] dgn provider
> I get an Iconnection error when using the below in providers.xml.
> Can someone help?
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Brad Nesom
> Sent: Friday, January 25, 2008 3:12 PM
> My providers.xml doesn't contain an ogr section. Does this look correct
> for what I need?
> <FeatureProvider>
> <Name>OSGeo.OGR.3.2</Name>
> <DisplayName>OSGeo FDO Provider for OGR </DisplayName>
> <Description>Read/write access to an OGR-based data store.
> </Description>
> <IsManaged>False</IsManaged>
> <Version>3.2.1.0</Version>
> <FeatureDataObjectsVersion>3.2.1.0</FeatureDataObjectsVersion>
> <LibraryPath>OGRProvider.dll</LibraryPath>
> </FeatureProvider>
> Sent: Friday, January 25, 2008 2:51 PM
> Subject: [fdo-users] dgn provider
> Has anyone ever heard of a microstation provider? I am having to ddo a
> bit of work on some dgns and return them to dgn. I know I can import
> them but they need to be built just like they came in when I export
> them. It would be so nice if I could use the fdo provider just like the
> shp provider and connect and edit them in place.
> Thanks
> Brad
> BTW the plan is to use map3d_08 to do whatever needs to be done.
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
