[fdo-users] dgn provider
Brad Nesom
kidsmake6 at msn.com
Fri Jan 25 18:35:29 EST 2008
It fails on the dgn but connects to the shp. ??
>>Did you set a plugin for the OGR provider?
Not sure what that means. I just placed the ogrprovider.dll in the fdo/bin
folder and added the section from below to the providers.xml.
Is that the default connection?
So I guess I am sure about my connection string now. Since I do get the shp
connected.
I attached my dgn. Does it work for you?
Brad
-----Original Message-----
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Robert Fortin
Sent: Friday, January 25, 2008 3:55 PM
To: FDO Users Mail List
Subject: RE: [fdo-users] dgn provider
Brad,
It seems to be failing in the Map plugin. Did you set a plugin for the OGR
provider?
If so, I would suggest you remove it and try it with the default connection
UI.
RF
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Brad Nesom
Sent: Friday, January 25, 2008 4:27 PM
To: 'FDO Users Mail List'
I get an Iconnection error when using the below in providers.xml.
Can someone help?
Sent: Friday, January 25, 2008 3:12 PM
My providers.xml doesn't contain an ogr section. Does this look correct for
what I need?
<FeatureProvider>
<Name>OSGeo.OGR.3.2</Name>
<DisplayName>OSGeo FDO Provider for OGR </DisplayName>
<Description>Read/write access to an OGR-based data store.
</Description>
<IsManaged>False</IsManaged>
<Version>3.2.1.0</Version>
<FeatureDataObjectsVersion>3.2.1.0</FeatureDataObjectsVersion>
<LibraryPath>OGRProvider.dll</LibraryPath>
</FeatureProvider>
Sent: Friday, January 25, 2008 2:51 PM
Subject: [fdo-users] dgn provider
Has anyone ever heard of a microstation provider? I am having to ddo a bit
of work on some dgns and return them to dgn. I know I can import them but
they need to be built just like they came in when I export them. It would be
so nice if I could use the fdo provider just like the shp provider and
connect and edit them in place.
Thanks
Brad
BTW the plan is to use map3d_08 to do whatever needs to be done.
fdo-users mailing list
fdo-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-users
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/fdo-users/attachments/20080125/bd45290a/00301pv-0001.obj
More information about the fdo-users
