[fdo-users] OGR 3.3 Provider runtime error
Traian Stanev
traian.stanev at autodesk.com
Wed Jan 30 19:40:11 EST 2008
Were you doing a Debug or Release build?
________________________________________
From: fdo-users-bounces at lists.osgeo.org [fdo-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng [jackie.ng at aecsystems.com.au]
Sent: Wednesday, January 30, 2008 7:20 PM
To: fdo-users at lists.osgeo.org
Subject: RE: [fdo-users] OGR 3.3 Provider runtime error
I've built FDO and providers from source, and still get the error.
I've set manifest to off in the OGRProvider vcproj file, rebuilt everything
from source, still no good.
I rewrote the C# test code in native C++, still the same error.
I'm out of ideas :(
- Jackie
Traian Stanev wrote:
> The depends dump looks good, however I just thought of what may be causing
> this. Some time ago Kenneth posted about a similar problem. I remember him
> mentioning that it was due to a manifest being embedded in the OGRProvider
> dll at build time. Removing the embedded manifest fixed the problem for
> him. We need to check the OGRProvider vcproj file for that problem and fix
> it if the manifest is turned on.
> Traian
> -----Original Message-----
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Traian Stanev
> Sent: Thursday, January 24, 2008 11:07 PM
> Depends can export the dependency graph to a file. If you could export
> yours and send it over I can take a quick look. Since the file can be
> large, email it to me only.
> Traian
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
> Sent: Thursday, January 24, 2008 11:04 PM
> That is correct, there are no red C++ functions listed.
> - Jackie
>> So, you open depends for OGRProvider.dll, pick FDO.dll from the tree-view
>> on the top left, and then look on the right side. It will show functions
>> from FDO.dll that the OGRProvider calls. Most of them will have a green
>> "C++" next to them. Are you saying none of them have a red C++ if you do
>> this?
>> Traian
>>> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-
>>> Sent: Tuesday, January 22, 2008 3:03 AM
>>> I've combed through the list of functions (OGRProvider.dll and directly
>>> related dlls) and couldn't find any red ones. However the log window
>>> did say
>>> there was at least one unresolved export function in one of the delay-
>>> load
>>> dependent modules, but it doesn't say which one??
>>> - Jackie
>>> > DWMAPI.dll is a common false positive that depends throws. That's not
>>> your
>>> > actual problem.
>>> > In depends, look in one of the right panes (the one in the middle,
>>> not the
>>> > top right), where it lists all the dependent DLL functions that are
>>> needed
>>> > by the provider. See if any of them are listed in red.
>>> > Traian
>>> > Sent: Monday, January 21, 2008 11:49 PM
>>> > Subject: [fdo-users] OGR 3.3 Provider runtime error
>>> > Hi List,
>>> > I have an application that interrogates a provider's connection
>>> > properties,
>>> > but when I want to get the connection properties of the OGR provider.
>>> I
>>> > get
>>> > the following error:
>>> > Microsoft Visual C++ Runtime Library
>>> > Runtime Error!
>>> > Program: [path to executable]
>>> > R6034
>>> > An Application has made an attempt to load the C runtime library
>>> > incorrectly.
>>> > Please contact the application's support team for more information.
>>> > If I run this through the vs debugger, I get an unhandled
>>> > OSGeo.FDO.Common.Exception with the following message.
>>> > "Unable to load the FDO Provider: A dynamic link library (DLL)
>>> > initialization routine failed."
>>> > Running OGRProvider.dll through depends.exe, I found that it was has
>>> a
>>> > missing dependency dwmapi.dll, which after some googling turns out to
>>> be a
>>> > Windows Vista dll (???). So I downloaded the file anyway, and put it
>>> into
>>> > the working directory, but I still get the same error messages.
>>> > I am using FDO 3.3.0 RC1 (binaries, not built from source) on Windows
>>> XP.
>>> > I am using the managed dlls.
>>> > Any ideas?
>>> > - Jackie
>>> > View this message in context:
>>> > http://www.nabble.com/OGR-3.3-Provider-runtime-error-
>>> tp15012644s18162p15012644.html
>>> > Sent from the fdo-users mailing list archive at Nabble.com.
>>> > _______________________________________________
>>> > http://lists.osgeo.org/mailman/listinfo/fdo-users
>>> View this message in context: http://www.nabble.com/OGR-3.3-Provider-
>>> runtime-error-tp15012644s18162p15014222.html
> http://www.nabble.com/OGR-3.3-Provider-runtime-error-tp15012644s18162p15080594.html
View this message in context: http://www.nabble.com/OGR-3.3-Provider-runtime-error-tp15012644s18162p15195091.html
More information about the fdo-users
