[fdo-users] Exception in FDO with PostGIS provider
gimbrogno magnitudo9 at email.it
Mon Jul 7 06:32:41 EDT 2008
I am trying to build mapguide v. 2.0.0 with fdo-3.3.0 and relative
providers...
Do you believe that this is a good solution? What FDo libs and Mapguide
Version are you using?
Thanks a lot...
gimbrogno wrote:
> I can see this in Error.log
> <2008-07-03T13:49:04>                   Administrator
>  Error: An exception occurred in FDO component.
>         The execution of Select command failed.
>  StackTrace:
>   - MgFeatureServiceHandler.ProcessOperation line 83 file
> FeatureServiceHandler.cpp
>   - MgOpSelectFeatures.Execute line 109 file OpSelectFeatures.cpp
>   - MgServerSelectFeatures.SelectFeatures line 249 file
> ServerSelectFeatures.cpp        An exception occurred in FDO component.
> Bruno Scott wrote:
>> Do you have something in the Mapguide error log?
View this message in context: http://www.nabble.com/Exception-in-FDO-with-PostGIS-provider-tp18231998p18313847.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
