[fdo-users] Exception in FDO with PostGIS provider
gimbrogno magnitudo9 at email.it
Mon Jul 7 12:10:22 EDT 2008
I also have compiled the ogr provider...
Can you help me to connect the postgresql db via ogr? Thanks
gimbrogno wrote:
> Hi all,
> I am a new FDO user and I have some problems with PostGIS provider. I made
> a demo table in PostGIS, with an Id (ogr_fid int4), a title (varchar(25))
> and a geometry column(POINT). When I try to connect Mapguide Studio via
> FDO, the connection test is OK, Mapguide Studio can find correctly the
> coordinate system that I used for the table (PostGIS_4326). When I click
> the preview, I can show the table but when I click "view data" or "view
> feature" I have this message " An exception occurred in FDO component. The
> execution of Select command failed. "
> The FDO libraries are running under a linux System (CentOS 5), and so also
> MapGuide O.S. 2.0.1.
> Can anyone helps me? Tanks in advance...
View this message in context: http://www.nabble.com/Exception-in-FDO-with-PostGIS-provider-tp18231998p18320304.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
