[fdo-users] Problem building FDO 3.3 with MySQL/ODBC on CentOS 5
Andy Morsell
amorsell at spatialgis.com
Thu Mar 13 22:19:29 EDT 2008
Hi Gavin,
I installed version 2.2.11-1 of unixODBC-core and unixODBC-devel. But, when
I do an rpm, it is showing 2.2.11-7.1 of core.
Thanks.
Gavin Cramer wrote:
> Hello, Andy. What version of unixodbc is installed?
> Gavin
> From: fdo-users-bounces at lists.osgeo.org
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Andy Morsell
> Sent: Thursday, March 13, 2008 7:27 PM
> To: fdo-users at lists.osgeo.org
> Subject: [fdo-users] Problem building FDO 3.3 with MySQL/ODBC on CentOS 5
> I'm trying to build FDO 3.3 on CentOS 5. I have been able to build with
> the core providers without MySQL / ODBC support, but when I attempt to
> build with that provider, it fails. It fails in the same place when using
> the FDO build_linux script with the --w rdbms switch, or when using the
> build_linux script separately from the GenericRdbms directory. It does
> not fail if running the FDO build_linux script with all default settings,
> but the FDO ODBC files are never created. I do have the MySQL client and
> developer libraries installed and correctly referenced via the FDOMYSQL
> environment variable. I also have the unixodbc libraries installed.
> Below is the last few lines of the build. Any insight on where to go next
> would be appreciated. Thank you.
> ../Rdbi/.libs/librdbi.a ../Util/.libs/libutil.a /usr/lib/libodbc.so -ldl
> -lpthread -lz -Wl,--rpath -Wl,/usr/local/fdo-3.3.0/lib
> ../ODBC/.libs/libFdoRdbmsODBC.a(FdoRdbmsOdbcConnection.o): In function
> `FdoRdbmsOdbcConnection::GetSchemaNameFromDsn()':
> FdoRdbmsOdbcConnection.cpp:(.text+0x1c8f): undefined reference to
> `SQLGetPrivateProfileString'
> collect2: ld returned 1 exit status
> make[3]: *** [UnitTestOdbc] Error 1
> make[3]: Leaving directory
> `/Software/FDO/OpenSource_FDO/Providers/GenericRdbms/Src/UnitTest'
> make[2]: *** [all-recursive] Error 1
> make[2]: Leaving directory
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory
> `/Software/FDO/OpenSource_FDO/Providers/GenericRdbms/Src'
> make: *** [all-recursive] Error 1
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> http://www.SpatialGIS.com
> fdo-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-users
View this message in context: http://www.nabble.com/Problem-building-FDO-3.3-with-MySQL-ODBC-on-CentOS-5-tp16041144s18162p16042947.html
Sent from the fdo-users mailing list archive at Nabble.com.
More information about the fdo-users
