[fdo-users] Ubuntu 7.10 MGOS 2.0 fcgi returns file instead of XML
    larry white
    larz at neomatix.ca
    Fri Mar 14 09:13:23 EDT 2008
Ed,
The installation/configuration of the mapguide.conf file seems to have
some issues.
In addition to the changes you've already made, you may also need to
uncomment the following line in mapguide.conf:
LoadModule mgmapagent_module modules/mod_mgmapagent.so
(this line is at the beginning of the file - line 8, in my case.)
Also, to gather information to figure things out, there are some log
files that can be quite useful
for apache issues:
  path_to_mapguide/webserverextensions/apache2/logs/error_log
for mapguide and fdo issues:
  path_to_mapguide/server/Logs
(btw, if you can't make heads-or-tails of what's going on in the logs,
posting information from them can aid others in helping out).
-- larry white
Sr. Systems Analyst
neomatix.ca
Ed Davis wrote:
> Map agent test returns .fcgi file instead of XML doc
> Previously posted and unresolved in discussion thread.
> Did try mod to
> /usr/local/mapguideopensource/webserverextensions/apache2/conf/mapguide.conf
> to uncomment AddHandler mgmapagent_handler fcgi
> *Ed Davis*
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
