[fdo-users] SelectAgregates error with King.Oracle provider 0.7.4
Haris Kurtagic
haris at sl-king.com
Fri Nov 7 05:07:31 EST 2008
King.Oracle doesn't support Select aggregate.
Workaround is to use SQL command to run SQLs.
Haris
-----Original Message-----
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Jackie C. Ng
Sent: Friday, November 07, 2008 7:37 AM
To: fdo-users at lists.osgeo.org
Subject: Re: [fdo-users] SelectAgregates error with King.Oracle provider
0.7.4
Yes this is a known issue
Either the command is actually implemented and the capabilities are
lying or
it is the other way round.
http://trac.osgeo.org/fdo/ticket/376
- Jackie
Eric de VISME wrote:
> Hello,
> I'm using the King.Oracle Provider to query my Oracle 10g database.
> The capabilities of the Fdo provider normally support the
SelectAggregates
> command and the Count operator.
> But, when I query the database with a "Select aggregates..." , I
receive
> the folowing error:
> "The command 'FdoCommandType_SelectAggregates' is not supported. "
> Is this issue already known ?
> Thanks in advance.
> Eric
http://themapguyde.blogspot.com
http://www.linkedin.com/in/jackieng
View this message in context:
http://www.nabble.com/SelectAgregates-error-with-King.Oracle-provider-0.
7.4-tp20107642p20375446.html
Sent from the FDO Users mailing list archive at Nabble.com.
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
