[fdo-users] SelectAgregates error with King.Oracle provider 0.7.4
Jackie C. Ng
jumpinjackie at gmail.com
Fri Nov 7 10:09:26 EST 2008
So the capabilities are wrong then.
I've attached a patch to that ticket that removes the unsupported command.
- Jackie
haris kurtagic wrote:
> King.Oracle doesn't support Select aggregate.
> Workaround is to use SQL command to run SQLs.
> Haris
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Jackie C. Ng
> Sent: Friday, November 07, 2008 7:37 AM
> To: fdo-users at lists.osgeo.org
> Subject: Re: [fdo-users] SelectAgregates error with King.Oracle provider
> 0.7.4
> Yes this is a known issue
> Either the command is actually implemented and the capabilities are
> lying or
> it is the other way round.
> http://trac.osgeo.org/fdo/ticket/376
> - Jackie
> Eric de VISME wrote:
>> Hello,
>> I'm using the King.Oracle Provider to query my Oracle 10g database.
>> The capabilities of the Fdo provider normally support the
> SelectAggregates
>> command and the Count operator.
>> But, when I query the database with a "Select aggregates..." , I
> receive
>> the folowing error:
>> "The command 'FdoCommandType_SelectAggregates' is not supported. "
>> Is this issue already known ?
>> Thanks in advance.
>> Eric
> http://themapguyde.blogspot.com
> http://www.linkedin.com/in/jackieng
> http://www.nabble.com/SelectAgregates-error-with-King.Oracle-provider-0.
> 7.4-tp20107642p20375446.html
> Sent from the FDO Users mailing list archive at Nabble.com.
> fdo-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-users
View this message in context: http://www.nabble.com/SelectAgregates-error-with-King.Oracle-provider-0.7.4-tp20107642p20382360.html
More information about the fdo-users
