[fdo-users] SelectAgregates error with King.Oracle provider 0.7.4
Eric de VISME
edevisme at geomapgis.com
Wed Nov 12 11:38:40 EST 2008
Thanks a lot for all these informations.
Eric
Jackie C. Ng wrote:
> So the capabilities are wrong then.
> I've attached a patch to that ticket that removes the unsupported command.
> - Jackie
> haris kurtagic wrote:
>> King.Oracle doesn't support Select aggregate.
>> Workaround is to use SQL command to run SQLs.
>> Haris
>> -----Original Message-----
>> From: fdo-users-bounces at lists.osgeo.org
>> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Jackie C. Ng
>> Sent: Friday, November 07, 2008 7:37 AM
>> To: fdo-users at lists.osgeo.org
>> Subject: Re: [fdo-users] SelectAgregates error with King.Oracle provider
>> 0.7.4
>> Yes this is a known issue
>> Either the command is actually implemented and the capabilities are
>> lying or
>> it is the other way round.
>> http://trac.osgeo.org/fdo/ticket/376
>> - Jackie
>> Eric de VISME wrote:
>>> Hello,
>>> I'm using the King.Oracle Provider to query my Oracle 10g database.
>>> The capabilities of the Fdo provider normally support the
>> SelectAggregates
>>> command and the Count operator.
>>> But, when I query the database with a "Select aggregates..." , I
>> receive
>>> the folowing error:
>>> "The command 'FdoCommandType_SelectAggregates' is not supported. "
>>> Is this issue already known ?
>>> Thanks in advance.
>>> Eric
>> http://themapguyde.blogspot.com
>> http://www.linkedin.com/in/jackieng
>> View this message in context:
>> http://www.nabble.com/SelectAgregates-error-with-King.Oracle-provider-0.
>> 7.4-tp20107642p20375446.html
>> Sent from the FDO Users mailing list archive at Nabble.com.
>> fdo-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/fdo-users
View this message in context: http://www.nabble.com/SelectAgregates-error-with-King.Oracle-provider-0.7.4-tp20107642p20464061.html
More information about the fdo-users
