[fdo-users] ArcSDE questions
Brad Nesom
kidsmake6 at msn.com
Wed Nov 12 12:18:30 EST 2008
Sorry, I didn't explain clearly.
5151 can be used directly for the service or esri_sde can be used.
> From: kidsmake6 at msn.com> To: fdo-users at lists.osgeo.org> Subject: RE: [fdo-users] ArcSDE questions> Date: Tue, 11 Nov 2008 23:59:51 -0600> > George,> 5151 is the normal sde port used when setting up (not necessarily how yours> was) also the service name is not the same as thedatabase service again if> you take the defaults it would probably be esri_sde> In my opinion you would probably need at least a few features in the feature> class in order for sde to create all the sde tables associated with the> feature class. You can use many methods to load some data. Including the> load command in arccatalog.> Brad> > -----Original Message-----> From: fdo-users-bounces at lists.osgeo.org> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of George McLean> Sent: Tuesday, November 11, 2008 6:13 PM> To: FDO Users Mail List> Subject: [fdo-users] ArcSDE questions> > I have a few of questions related to ArcSDE.> > I am using ArcSDE 9.3 with SQLServer 2005 as the database and the dbo > user. I am starting with an empty schema. Through ArcCatalog I have > created a line feature class. However, I can not see the feature class > listed when I connect through Autocad Map's display manager. When I > connect there are no features listed to bring onto the map. Not having > much experience with ArcCatalog, I would like to know if creating a > feature class is what I need to do to see features in Autocad. If so, > are there any special considerations in building the feature class?> > Also, at this point there is no data in the feature class. Could this be > why it is not listed in the display manger connection?> > Finally, I have some .net code that I use to port data from Autocad into > an FDO datastore. It works with Oracle and MySQL. I am not sure of the > connection strong parameters required to connect to ArcSDE. In my code I > create a string as follows:> > "service=MyService; username=MyUser; password=MyPass; datastore=MyDataStore"> > What I am not sure about is what to put in for MyService and MyDataStore > when using ArcSDE.> > I have tried the GIS server name for MyService and the schema name for > MyDataStore but I can not connect.> > Any guidance on any of these questions would be greatly appreciated!> > Thanks> > George McLean> > > _______________________________________________> fdo-users mailing list> fdo-users at lists.osgeo.org> http://lists.osgeo.org/mailman/listinfo/fdo-users> > _______________________________________________> fdo-users mailing list> fdo-users at lists.osgeo.org> http://lists.osgeo.org/mailman/listinfo/fdo-users
_________________________________________________________________
Get 5 GB of storage with Windows Live Hotmail.
http://windowslive.com/Explore/Hotmail?ocid=TXT_TAGLM_WL_hotmail_acq_5gb_112008
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20081112/f8963441/attachment.html
More information about the fdo-users
