[fdo-users] ArcSDE questions
Brad Nesom
kidsmake6 at msn.com
Wed Nov 12 00:59:51 EST 2008
George,
5151 is the normal sde port used when setting up (not necessarily how yours
was) also the service name is not the same as thedatabase service again if
you take the defaults it would probably be esri_sde
In my opinion you would probably need at least a few features in the feature
class in order for sde to create all the sde tables associated with the
feature class. You can use many methods to load some data. Including the
load command in arccatalog.
Brad
-----Original Message-----
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of George McLean
Sent: Tuesday, November 11, 2008 6:13 PM
To: FDO Users Mail List
Subject: [fdo-users] ArcSDE questions
I have a few of questions related to ArcSDE.
I am using ArcSDE 9.3 with SQLServer 2005 as the database and the dbo
user. I am starting with an empty schema. Through ArcCatalog I have
created a line feature class. However, I can not see the feature class
listed when I connect through Autocad Map's display manager. When I
connect there are no features listed to bring onto the map. Not having
much experience with ArcCatalog, I would like to know if creating a
feature class is what I need to do to see features in Autocad. If so,
are there any special considerations in building the feature class?
Also, at this point there is no data in the feature class. Could this be
why it is not listed in the display manger connection?
Finally, I have some .net code that I use to port data from Autocad into
an FDO datastore. It works with Oracle and MySQL. I am not sure of the
connection strong parameters required to connect to ArcSDE. In my code I
create a string as follows:
"service=MyService; username=MyUser; password=MyPass; datastore=MyDataStore"
What I am not sure about is what to put in for MyService and MyDataStore
when using ArcSDE.
I have tried the GIS server name for MyService and the schema name for
MyDataStore but I can not connect.
Any guidance on any of these questions would be greatly appreciated!
Thanks
George McLean
fdo-users mailing list
fdo-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
