[fdo-users] bulkcopy ArcSDE -> SQLite
Jackie C. Ng jumpinjackie at gmail.com
Wed Nov 12 15:49:33 EST 2008
That's a question that should be asked to Autodesk (or their official
discussion channels) instead, as the BulkCopy component is part of the Map
ObjectARX SDK and not the open source FDO.
But I would guess in theory any provider is a valid bulk copy source and any
provider that supports write and schema creation/modification is a valid
bulk copy target.
- Jackie
alucas wrote:
> Hi Jackie,
> I don't try this option. I'll see this in the next days. My question is
> about if the provider will support bulkcopy operations with AutoCAD Map
> 3D.
> Thanks.
> Jackie C. Ng wrote:
>> Have you tried using FDO Toolbox to do this?
>> - Jackie
>> alucas wrote:
>>> Hello,
>>> It's possible to do this bulkcopy?
>>> Thanks in advance.
>>> View this message in context:
>>> http://www.nabble.com/bulkcopy-ArcSDE--%3E-SQLite-tp20416688p20416688.html
>>> Sent from the FDO Users mailing list archive at Nabble.com.
>>> fdo-users mailing list
>>> fdo-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/fdo-users
>> http://n2.nabble.com/bulkcopy-ArcSDE--%3E-SQLite-tp1479828p1482578.html
>> http://themapguyde.blogspot.com
>> http://www.linkedin.com/in/jackieng
View this message in context: http://www.nabble.com/bulkcopy-ArcSDE--%3E-SQLite-tp20416688p20469080.html
More information about the fdo-users mailing list
