[fdo-users] bulkcopy ArcSDE -> SQLite
Robert Fortin
robert.fortin at autodesk.com
Wed Nov 12 16:42:31 EST 2008
Jackie is right all the way.
ArcSDE provider doesn't let you create or modify new schema so you must have an existing schema for ArcSDE and do the mapping between the source and the target schema. The most common problem encountered is a wrong mapping to the existing schema which triggers Bulkcopy to try to alter the schema. This fails because the provider doesn't support schema creation/modification.
RF
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Jackie C. Ng
Sent: Wednesday, November 12, 2008 3:50 PM
To: fdo-users at lists.osgeo.org
Subject: Re: [fdo-users] bulkcopy ArcSDE -> SQLite
That's a question that should be asked to Autodesk (or their official
discussion channels) instead, as the BulkCopy component is part of the Map
ObjectARX SDK and not the open source FDO.
But I would guess in theory any provider is a valid bulk copy source and any
provider that supports write and schema creation/modification is a valid
bulk copy target.
- Jackie
alucas wrote:
> Hi Jackie,
> I don't try this option. I'll see this in the next days. My question is
> about if the provider will support bulkcopy operations with AutoCAD Map
> 3D.
> Thanks.
> Jackie C. Ng wrote:
>> Have you tried using FDO Toolbox to do this?
>> - Jackie
>> alucas wrote:
>>> Hello,
>>> It's possible to do this bulkcopy?
>>> Thanks in advance.
>>> View this message in context:
>>> http://www.nabble.com/bulkcopy-ArcSDE--%3E-SQLite-tp20416688p20416688.html
>>> Sent from the FDO Users mailing list archive at Nabble.com.
>>> fdo-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/fdo-users
>> http://n2.nabble.com/bulkcopy-ArcSDE--%3E-SQLite-tp1479828p1482578.html
>> http://themapguyde.blogspot.com
>> http://www.linkedin.com/in/jackieng
View this message in context: http://www.nabble.com/bulkcopy-ArcSDE--%3E-SQLite-tp20416688p20469080.html
More information about the fdo-users
