[fdo-users] bulkcopy ArcSDE -> SQLite
Jackie C. Ng
jumpinjackie at gmail.com
Thu Nov 13 07:21:00 EST 2008
That is correct.
- Jackie
alucas wrote:
> Hi Robert,
> I understand this, but I only need to do the bulkcopy from ArcSDE ->
> SQLite. So, I think that schema creation is only required for SQLite
> provider. So, if SQLite provider allows schema creation, in theory I can
> bulkcopy the data from any source.
> Is this correct?
> Thanks.
> P.D: Sorry for my english.
> Robert Fortin wrote:
>> Jackie is right all the way.
>> ArcSDE provider doesn't let you create or modify new schema so you must
>> have an existing schema for ArcSDE and do the mapping between the source
>> and the target schema. The most common problem encountered is a wrong
>> mapping to the existing schema which triggers Bulkcopy to try to alter
>> the schema. This fails because the provider doesn't support schema
>> creation/modification.
>> RF
>> -----Original Message-----
>> From: fdo-users-bounces at lists.osgeo.org
>> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Jackie C. Ng
>> Sent: Wednesday, November 12, 2008 3:50 PM
>> To: fdo-users at lists.osgeo.org
>> Subject: Re: [fdo-users] bulkcopy ArcSDE -> SQLite
>> That's a question that should be asked to Autodesk (or their official
>> discussion channels) instead, as the BulkCopy component is part of the
>> Map
>> ObjectARX SDK and not the open source FDO.
>> But I would guess in theory any provider is a valid bulk copy source and
>> any
>> provider that supports write and schema creation/modification is a valid
>> bulk copy target.
>> - Jackie
>> alucas wrote:
>>> Hi Jackie,
>>> I don't try this option. I'll see this in the next days. My question is
>>> about if the provider will support bulkcopy operations with AutoCAD Map
>>> 3D.
>>> Thanks.
>>> Jackie C. Ng wrote:
>>>> Have you tried using FDO Toolbox to do this?
>>>> - Jackie
>>>> alucas wrote:
>>>>> Hello,
>>>>> It's possible to do this bulkcopy?
>>>>> Thanks in advance.
>>>>> View this message in context:
>>>>> http://www.nabble.com/bulkcopy-ArcSDE--%3E-SQLite-tp20416688p20416688.html
>>>>> Sent from the FDO Users mailing list archive at Nabble.com.
>>>>> _______________________________________________
>>>>> fdo-users mailing list
>>>>> http://lists.osgeo.org/mailman/listinfo/fdo-users
>>>> http://n2.nabble.com/bulkcopy-ArcSDE--%3E-SQLite-tp1479828p1482578.html
>>>> http://themapguyde.blogspot.com
>>>> http://www.linkedin.com/in/jackieng
>> http://www.nabble.com/bulkcopy-ArcSDE--%3E-SQLite-tp20416688p20469080.html
View this message in context: http://www.nabble.com/bulkcopy-ArcSDE--%3E-SQLite-tp20416688p20479763.html
More information about the fdo-users
