[fdo-users] bulkcopy ArcSDE -> SQLite
Traian Stanev
traian.stanev at autodesk.com
Thu Nov 13 08:15:27 EST 2008
SQLite allows schema creation. As I said, in theory it should be possible, except that nobody has tried it in practice. SQLite behaves a lot like SDF but there are some differences during ApplySchema, there is no guarantee it works until it's verified experimentally.
Traian
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-
> bounces at lists.osgeo.org] On Behalf Of alucas
> Sent: Thursday, November 13, 2008 3:39 AM
> To: fdo-users at lists.osgeo.org
> Subject: RE: [fdo-users] bulkcopy ArcSDE -> SQLite
> Hi Robert,
> I understand this, but I only need to do the bulkcopy from ArcSDE ->
> SQLite.
> So, I think that schema creation is only required for SQLite provider.
> So,
> if SQLite provider allows schema creation, in theory I can bulkcopy the
> data
> from any source.
> Is this correct?
> Thanks.
> P.D: Sorry for my english.
> Robert Fortin wrote:
> > Jackie is right all the way.
> > ArcSDE provider doesn't let you create or modify new schema so you
> must
> > have an existing schema for ArcSDE and do the mapping between the
> source
> > and the target schema. The most common problem encountered is a wrong
> > mapping to the existing schema which triggers Bulkcopy to try to
> alter the
> > schema. This fails because the provider doesn't support schema
> > creation/modification.
> > RF
> > [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Jackie C. Ng
> > Sent: Wednesday, November 12, 2008 3:50 PM
> > Subject: Re: [fdo-users] bulkcopy ArcSDE -> SQLite
> > That's a question that should be asked to Autodesk (or their official
> > discussion channels) instead, as the BulkCopy component is part of
> the Map
> > ObjectARX SDK and not the open source FDO.
> > But I would guess in theory any provider is a valid bulk copy source
> and
> > any
> > provider that supports write and schema creation/modification is a
> valid
> > bulk copy target.
> > - Jackie
> > alucas wrote:
> >> Hi Jackie,
> >> I don't try this option. I'll see this in the next days. My question
> is
> >> about if the provider will support bulkcopy operations with AutoCAD
> Map
> >> 3D.
> >> Thanks.
> >> Jackie C. Ng wrote:
> >>> Have you tried using FDO Toolbox to do this?
> >>> - Jackie
> >>> alucas wrote:
> >>>> Hello,
> >>>> It's possible to do this bulkcopy?
> >>>> Thanks in advance.
> >>>> View this message in context:
> >>>> http://www.nabble.com/bulkcopy-ArcSDE--%3E-SQLite-
> tp20416688p20416688.html
> >>>> Sent from the FDO Users mailing list archive at Nabble.com.
> >>>> _______________________________________________
> >>>> fdo-users mailing list
> >>>> http://lists.osgeo.org/mailman/listinfo/fdo-users
> >>> http://n2.nabble.com/bulkcopy-ArcSDE--%3E-SQLite-
> tp1479828p1482578.html
> >>> http://themapguyde.blogspot.com
> >>> http://www.linkedin.com/in/jackieng
> tp20416688p20469080.html
> View this message in context: http://www.nabble.com/bulkcopy-ArcSDE--
> %3E-SQLite-tp20416688p20476696.html
More information about the fdo-users
