[fdo-users] SDE Connection Parameters
Brad Nesom kidsmake6 at msn.com
Thu Oct 9 23:07:13 EDT 2008
Thanks Robert,
 I had not ever found any of this. I am trying it now. I will let you know what I learn.
Brad
From: robert.fortin at autodesk.comTo: fdo-users at lists.osgeo.orgDate: Thu, 9 Oct 2008 08:33:32 -0700Subject: RE: [fdo-users] SDE Connection Parameters
Brad,
Have you tried setting up the etc/services file and using this to conect to ArcSDE instead of the 5151 port? See http://fdo.osgeo.org/files/fdo/docs/FET_TheEssentialFDO/index.html
Also is that in direct connect mode?
Robert Fortin
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Brad NesomSent: Wednesday, October 01, 2008 1:39 PMTo: FDO Users Mail ListSubject: RE: [fdo-users] SDE Connection Parameters
Good thing Rob,you didn't happen to come across the same for sde lite and sql server lite did you> Date: Wed, 1 Oct 2008 07:13:47 -0700> From: Rob.Sosnowski at itd.idaho.gov> To: fdo-users at lists.osgeo.org> Subject: Re: [fdo-users] SDE Connection Parameters> > > RESOLVED:> > IConnectionManager connectionManager => FeatureAccessManager.GetConnectionManager();> IConnection connection => connectionManager.CreateConnection(providerName);> IConnectionPropertyDictionary connectionPropertyDictionary;> connectionPropertyDictionary => connection.ConnectionInfo.ConnectionProperties;> connectionPropertyDictionary.SetProperty("Server",> "servername");> connectionPropertyDictionary.SetProperty("Instance", "5151");> connectionPropertyDictionary.SetProperty("Username",> "username");> connectionPropertyDictionary.SetProperty("Password",> "password");> connectionPropertyDictionary.SetProperty("Datastore",> "database");> OSGeo.FDO.Connections.ConnectionState connectState => connection.Open();> > > surrounded wrote:> > > > Hi,> > > > Been using FDO with shapefiles; now I wish to use with SDE layers. Can> > someone provide me with the code to make a connection to a SDE database. > > Our SDE layers are on MS SQL Server if that is important.> > > > Thanks.....Rob> > > > > > -- > View this message in context: http://n2.nabble.com/SDE-Connection-Parameters-tp1129033p1131481.html> Sent from the FDO Users mailing list archive at Nabble.com.> > _______________________________________________> fdo-users mailing list> fdo-users at lists.osgeo.org> http://lists.osgeo.org/mailman/listinfo/fdo-users
See how Windows connects the people, information, and fun that are part of your life. See Now
_________________________________________________________________
Get more out of the Web. Learn 10 hidden secrets of Windows Live.
http://windowslive.com/connect/post/jamiethomson.spaces.live.com-Blog-cns!550F681DAD532637!5295.entry?ocid=TXT_TAGLM_WL_domore_092008
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20081009/370910c2/attachment.html
More information about the fdo-users mailing list
