[fdo-users] Arc SDE 9.3
Brad Nesom
kidsmake6 at msn.com
Wed Oct 22 17:59:52 EDT 2008
> From: robert.fortin at autodesk.com> To: fdo-users at lists.osgeo.org> Date: Tue, 21 Oct 2008 12:33:14 -0700> Subject: RE: [fdo-users] Arc SDE 9.3> > Just a clarification around direct connect: this applies to the provider itself. Some application might have issue because it won't let you enter the connection parameters in order to connect properly.> > Additional information on how to setup direct connect should clarify this.
Robert,
Will you let us know when and where this documentation is when you get it done?
Thanks
Brad> > RF> > -----Original Message-----> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Robert Fortin> Sent: Tuesday, October 21, 2008 3:20 PM> To: FDO Users Mail List> Subject: RE: [fdo-users] Arc SDE 9.3> > Jason,> > I just double checked with our developer: The only issue we found was due to the CreateSpatialContext command. That has not been fixed yet. That forces us to hand craft our unit test since this command was used to build the data set. But in the case of ArcSDE provider, this is not a command that you are likely to use as the schema is already created using ArcSDE tools.> > So, as long as you use the provider on Windows, without dbo user and without Windows Authentication, you should be able to use the 3.3.2 provider to connect to ArcSDE 9.3 using either 9.2 or 9.3 client dlls. I read that there was some restriction using 9.2 client with SP5 and above but I think it has to do with direct connect mode only.> > BTW I'm trying to the get info on how to setup direct connect on the FDO site. I think this should also work for FDO 3.3.2 but we really just tested it with FDO 3.4 so far.> > RF> > -----Original Message-----> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch> Sent: Tuesday, October 21, 2008 2:41 PM> To: FDO Users Mail List> Subject: RE: [fdo-users] Arc SDE 9.3> > Robert, was the 9.3 support backported to FDO 3.3 (for inclusion in 3.3.2), or will users have to wait for the 2010 products to appear in order to take advantage of this?> > Thanks,> Jason> > -----Original Message-----> From: Robert Fortin> Subject: RE: [fdo-users] Arc SDE 9.3> > As Romy mentioned, you can download the latest patch for the provider depending on the version of FDO you want to use. Go to the FDO download page http://fdo.osgeo.org/content/downloads.
_________________________________________________________________
Stay organized with simple drag and drop from Windows Live Hotmail.
http://windowslive.com/Explore/hotmail?ocid=TXT_TAGLM_WL_hotmail_102008
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20081022/0a318f1c/attachment.html
More information about the fdo-users
