[fdo-users] OGR/TAB write access?
Traian Stanev traian.stanev at autodesk.com
Tue Sep 16 12:23:31 EDT 2008
OGR has write access, because it can create a new TAB file, but it does not support update of existing files. Are you trying to create a new TAB file? If yes, then it would not be possible with the current OGR provider, since it does not map the OGRDataSource::CreateDataSource() API.
Traian
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-
> bounces at lists.osgeo.org] On Behalf Of Bruno Scott
> Sent: Tuesday, September 16, 2008 12:06 PM
> To: fdo-users at lists.osgeo.org
> Subject: [fdo-users] OGR/TAB write access?
> Is it possible to establish a write connection to a MapInfo TAB file?
> I have no problem creating a read-only connection
> But as soon as i specify ReadOnly=FALSE i got a connection failed.
> OGR is supposed to support write access and MITAB also!
> Is there something i missed?
> Thanks
> Bruno
> View this message in context: http://www.nabble.com/OGR-TAB-write-
> access--tp19514942p19514942.html
> Sent from the FDO Users mailing list archive at Nabble.com.
> fdo-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users mailing list
