[fdo-users] Where can I find the PostGIS 8.2.5 binaries ?
Traian Stanev
traian.stanev at autodesk.com
Tue Aug 4 12:19:45 EDT 2009
No idea why, those two builds have been specifically tested to work with PostGIS on FDO 3.3 (which should be what Map 2009 uses).
Also, I don’t fully understand what you mean by “OGR connection runs but the PostGIS connection doesn’t”.
Traian
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of RGC
Sent: Tuesday, August 04, 2009 2:31 AM
To: fdo-users at lists.osgeo.org
Subject: RE: [fdo-users] Where can I find the PostGIS 8.2.5 binaries ?
Thank you Traian, but with the alternative provider DLL you posted it
still not working properly. In the FDO menu, the OGR Conections runs, but
the PostGIS conection doesn't.
Any idea?
Thanks in advance
RGC
| De: |
|"Traian Stanev (via Nabble)" <[hidden email]<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=3382788&i=0>> |
| Para: |
|RGC <[hidden email]<http://n2.nabble.com/user/SendEmail.jtp?type=node&node=3382788&i=1>> |
| Fecha: |
|03/08/2009 17:44 |
| Asunto: |
|RE: [fdo-users] Where can I find the PostGIS 8.2.5 binaries ? |
You can also try either of the following alternative provider DLL builds to
see if it makes a difference:
http://13-9.com/OGRProvider-3.3.0.zip
http://13-9.com/OGRProvider-3.3-utf8.zip
Traian
> -----Original Message-----
> From: [hidden email] [mailto:fdo-users-
> [hidden email]] On Behalf Of RGC
> Sent: Monday, August 03, 2009 2:06 AM
> To: [hidden email]
> Subject: [fdo-users] Where can I find the PostGIS 8.2.5 binaries ?
> Hi all.
> I can´t configure the OGR driver provider to my FDO conections in Autocad
> Map 2009.
> Autocad Map 2009 needs the PostGIS 8.2.5 binaries, but in the URL
> http://n2.nabble.com/FDO-Users-f2048584.html, I have tried several links
in
> this download page, but it seems that none is working.
> Anybody can tell me where can I find this binaries or send to me?
> Thanks
> Rafa
> PD: I´ve tried with others versions of the PostGIS binaries but the FDO
> connection not work properly.
> View this message in context: http://n2.nabble.com/Where-can-I-find-the-
> PostGIS-8.2.5-binaries---tp3376079p3376079.html
> Sent from the FDO Users mailing list archive at Nabble.com.
> fdo-users mailing list
> [hidden email]
> http://lists.osgeo.org/mailman/listinfo/fdo-users
[hidden email]
View message @
http://n2.nabble.com/Where-can-I-find-the-PostGIS-8.2.5-binaries---tp3376079p3378551.html
To unsubscribe from Where can I find the PostGIS 8.2.5 binaries ?, click
here.
View this message in context: RE: [fdo-users] Where can I find the PostGIS 8.2.5 binaries ?<http://n2.nabble.com/Where-can-I-find-the-PostGIS-8.2.5-binaries---tp3376079p3382788.html>
Sent from the FDO Users mailing list archive<http://n2.nabble.com/FDO-Users-f2048584.html> at Nabble.com.
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20090804/932be2d3/attachment.html
More information about the fdo-users
