AW: [fdo-users] Trying to get FDO-Postgis to work in Topobase Map 2010
Hermann Karl
Karl.Hermann at dornbirn.at
Tue Aug 11 08:18:56 EDT 2009
Hi Andreas,
http://geospatialfrance.typepad.com/geospatialfrance/2007/09/fournisseur-fdo.html
http://www.bricscad.bplaced.net/html/mapguide_und_postgis.html
Karl
-----Ursprüngliche Nachricht-----
Von: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] Im Auftrag von Andreas Neumann
Gesendet: Dienstag, 11. August 2009 11:45
An: fdo-users at lists.osgeo.org
Betreff: [fdo-users] Trying to get FDO-Postgis to work in Topobase Map 2010
Hi all,
I am trying to get the FDO Postgis provider to work in my Topobase 2010 installation (which is built on top of Map3D 2010).
I followed the instructions at http://trac.osgeo.org/fdo/wiki/FdoPostGISNotes
but when I'm trying to load the data provider I get the following error message (I am translating from german, since it is a german error
message):
"Connection-Element for Provider could not be loaded. Either the provider is not installed, or an error occured while accessing the module"
See screenshot attached with the original german error message.
Is there a dll-missing or of wrong version? I copied some Dlls from
pgadmin3 to fdo/bin, incl.
* comerr32.dll
* gssapi32.dll
* k5sprt32.dll
* libeay32.dll
* libiconv-2.dll
* libintl-8.dll
* libpg.dll
* msvcr90.dll
* dwmapi.dll
I checked PostGISProvider.dll with the dependency walker and it did not complain about missing dlls - but it issued a warning: "At least one module has an unresolved import due to a missing export function in a delay-load dependent module".
Any idea on what may be wrong that the Postgis-Provider doesn't load?
I am on WindowsXP, SP3.
Thanks,
Andreas
Andreas Neumann
http://www.carto.net/neumann/
http://www.svgopen.org/
More information about the fdo-users
