[fdo-users] Trying to get FDO-Postgis to work in Topobase Map
2010
Andreas Neumann
a.neumann at carto.net
Wed Aug 12 07:35:06 EDT 2009
Hi Gwenael,
Unfortunately it is still not working. I still do have hope though it will
work. I had the krb5_32.dll in the fdo/bin directory, but forgot to list
it in my list of dlls I copied - my fault.
Here are some followup questions:
* From which source/version should I take the dlls? I took them from the
newest pgadmin3 client, which I believe is on par with PostgreSQL 8.4.
However, I also tried copying the DLLs from a regular PostgreSQL server
install from version 8.3 and 8.2 - neither one worked.
* is the FDO-Postgis provider known to work with Topobase 2010? Maybe
there is something in Topobase that makes it different from the regular
Map3D versions?
Is there any way to get more meaningful error messages than just "could
not load the module"?
Thank you for additional ideas on what may be wrong on my system.
Andreas
On Tue, August 11, 2009 2:13 pm, Gwenael Bachelot wrote:
> Hi Andreas,
> It seems you are still missing a dll.
> If I compare to the list of files I need for Map 3D 2010, you miss
> krb5_32.dll.
> Perhaps could you try to add it, and restart TB 2010 ?
> Cordialement,
> Gwenael
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Andreas Neumann
> Sent: mardi 11 août 2009 11:45
> To: fdo-users at lists.osgeo.org
> Subject: [fdo-users] Trying to get FDO-Postgis to work in Topobase Map
> 2010
> Hi all,
> I am trying to get the FDO Postgis provider to work in my Topobase 2010
> installation (which is built on top of Map3D 2010).
> I followed the instructions at
> http://trac.osgeo.org/fdo/wiki/FdoPostGISNotes
> but when I'm trying to load the data provider I get the following error
> message (I am translating from german, since it is a german error
> message):
> "Connection-Element for Provider could not be loaded. Either the provider
> is not installed, or an error occured while accessing the module"
> See screenshot attached with the original german error message.
> Is there a dll-missing or of wrong version? I copied some Dlls from
> pgadmin3 to fdo/bin, incl.
> * comerr32.dll
> * gssapi32.dll
> * k5sprt32.dll
> * libeay32.dll
> * libiconv-2.dll
> * libintl-8.dll
> * libpg.dll
> * msvcr90.dll
> * dwmapi.dll
> I checked PostGISProvider.dll with the dependency walker and it did not
> complain about missing dlls - but it issued a warning: "At least one
> module has an unresolved import due to a missing export function in a
> delay-load dependent module".
> Any idea on what may be wrong that the Postgis-Provider doesn't load?
> I am on WindowsXP, SP3.
> Thanks,
> Andreas
> Andreas Neumann
> http://www.carto.net/neumann/
> http://www.svgopen.org/
> fdo-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-users
Andreas Neumann
More information about the fdo-users
