[fdo-users] 3.3.2 Source Files with Unexpected Names
Greg Boone greg.boone at autodesk.com
Fri Feb 13 11:10:20 EST 2009
Did you install ActivePerl? If so, which version?
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Bob Cave
Sent: Friday, February 13, 2009 9:52 AM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] 3.3.2 Source Files with Unexpected Names
I am building FDO 3.3.2 on Windows.  I have run SetEnvironment.bat to
initialize the environment, then launched Visual Studio 2005 from that
command line session so that it will have the environment set up correctly.
While building XercesLib, I got errors saying that various header files
could not be found:
xercesc/validators/schema/identity/XercesXPath.hpp
xercesc/validators/schema/identity/IC_Selector.hpp
xercesc/framework/psvi/XSComplexTypeDefinition.hpp
When I looked in the directories where those files were supposed to be, I
found files with those names, but with a suffix of 0000644 (e.g.,
XercesXPath.hpp0000644).  Are these files supposed to be generated by the
configuration process?  When I ran SetEnvironment.bat, I didn't get any
error messages, but I did get messages saying I do not have several of the
optional items.  Since those items are optional, I decided to continue
without them.  Maybe that was not the best course of action.
Can I just rename these files, or do I have a configuration issue?
Thanks,
Bob
View this message in context: http://n2.nabble.com/3.3.2-Source-Files-with-Unexpected-Names-tp2321595p2321595.html
Sent from the FDO Users mailing list archive at Nabble.com.
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users mailing list
