[fdo-users] AutoCAD Map 3D 2009 and FDO PostGIS Provider 3.3
problems with installation
Astrid Emde (WhereGroup)
astrid.emde at wheregroup.com
Wed Jan 14 12:20:54 EST 2009
Hello devs,
I would like to test AutoCAD Map 3d 2009 and FDO for Postgresql.
I followed the instruction at http://trac.osgeo.org/fdo/wiki/FdoPostGISNotes
Here is what I did:
1. german installation of AutoCAD Map 3D 2009
2. download of the package (Logged FdoPg33L.zip ) at
http://www.geomapgis.com/web/geomap-group/fdo/index.html
I took the package Logged FdoPg33L.zip but I don't know the difference
between logged and not logged
* Not Logged FdoPg33.zip
* Logged FdoPg33L.zip
3. I copied the tree dlls to:
C:\Autodesk\AutoCAD_Map3D_2009_German_Win_32bit\x86\de-DE\Fdo\Program
Files\Root\FDO\bin
This is the FDO directory where I found the other dlls and the providers.xml
4. I added the FeatureProvider to
Files\Root\FDO\bin\providers.xml (I edited the Versions 3.3.0.0)
<FeatureProvider>
<Name>OSGeo.PostGIS.3.3</Name>
<DisplayName>OSGeo FDO Provider for PostGIS</DisplayName>
<Description>FDO Provider for PostGIS</Description>
<IsManaged>False</IsManaged>
<Version>3.3.0.0</Version>
<FeatureDataObjectsVersion>3.3.0.0</FeatureDataObjectsVersion>
<LibraryPath>.\PostGISProvider.dll</LibraryPath>
</FeatureProvider>
5. I installed Postgresql 8.2.5-1 and Postgis 1.3.5-1
6. I added the path to the postgresql bin directory to the PATH variable:
PATH C:\Program
Files\PostgreSQL\8.2\bin;%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem
7. I restarted the computer
8. I started AutoCAD Map 3D 2009
9. in the menu you can choose Datei - Mit Daten verbinden (english
translation could be: File - Connect with data)
I expeted that there would be another entry for the FDO PostgreSQL
connection, but there isn't.
Do you have an idea what I made wrong? Is there another location, another
file where I have to make changes?
I found another /fdo/bin-directory where I found some more
OSGeo.FDO.Providers......dlls (like
OSGeo.FDO.Providers.MySQL.Overrides.dll)
C:\Autodesk\AutoCAD_Map3D_2009_German_Win_32bit\x86\Program
Files\Root\FDO\bin
Sorry - I really have no experience with AutoCAD Map3D 2009 and of the FDO
part. But I would like to test the
possibility to edit the PostgreSQL/PostGIS data which is stored in the
PostgreSQL database directly through the fdo connection.
As I read at
* http://trac.osgeo.org/fdo/wiki/FdoPostGISNotes
* or http://lists.osgeo.org/pipermail/fdo-users/2008-November/001325.html
it should generally work with 3.3 fdo PostGIS provider.
Maybe you could help me to manage the problems that I have at the very
beginning.
Thanks in advance
Astrid
FOSSGIS Konferenz 2009
17.-19. März 2009 in Hannover
http://www.fossgis.de/konferenz
More information about the fdo-users
