[fdo-users] AutoCAD Map 3D 2009 and FDO PostGIS Provider 3.3 problems with installation
Gwenael Bachelot gwenael.bachelot at eur.autodesk.com
Fri Jan 16 10:22:25 EST 2009
Hi Astrid,
2. The "Logged" version creates a log of the operations.
The "notLogged" doesn't.
3. This seems more to be a copy of the installation DVD, more than the actual installation directory. Take a look in C:\Program Files\AutoCAD Map 3D 2009\FDO\bin, which is the default install directory.
4. Seems ok also
5. Seems ok also.
9. You should see the new entry in the list of providers (see a screenshots at http://geospatialfrance.typepad.com/geospatialfrance/2007/09/fournisseur-fdo.html, and a video at http://geospatialfrance.typepad.com/geospatialfrance/2008/12/autocad-map-3d-2009-mapguide-et-postgis.html).
Cordialement,
Gwenael
Gwenael Bachelot - Mailto:gwenael.bachelot at autodesk.com
http://www.geospatial-made-in-france.fr
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Astrid Emde (WhereGroup)
Sent: mercredi 14 janvier 2009 18:21
To: fdo-users at lists.osgeo.org
Cc: gbergrath-ebw at wesseling.de
Subject: [fdo-users] AutoCAD Map 3D 2009 and FDO PostGIS Provider 3.3 problems with installation
Hello devs,
I would like to test AutoCAD Map 3d 2009 and FDO for Postgresql.
I followed the instruction at http://trac.osgeo.org/fdo/wiki/FdoPostGISNotes
Here is what I did:
1. german installation of AutoCAD Map 3D 2009
2. download of the package (Logged FdoPg33L.zip ) at
http://www.geomapgis.com/web/geomap-group/fdo/index.html
I took the package Logged FdoPg33L.zip but I don't know the difference
between logged and not logged
* Not Logged FdoPg33.zip
* Logged FdoPg33L.zip
3. I copied the tree dlls to:
C:\Autodesk\AutoCAD_Map3D_2009_German_Win_32bit\x86\de-DE\Fdo\Program
Files\Root\FDO\bin
This is the FDO directory where I found the other dlls and the providers.xml
4. I added the FeatureProvider to
Files\Root\FDO\bin\providers.xml (I edited the Versions 3.3.0.0)
  <FeatureProvider>
    <Name>OSGeo.PostGIS.3.3</Name>
    <DisplayName>OSGeo FDO Provider for PostGIS</DisplayName>
    <Description>FDO Provider for PostGIS</Description>
    <IsManaged>False</IsManaged>
    <Version>3.3.0.0</Version>
    <FeatureDataObjectsVersion>3.3.0.0</FeatureDataObjectsVersion>
    <LibraryPath>.\PostGISProvider.dll</LibraryPath>
  </FeatureProvider>
5. I installed Postgresql 8.2.5-1 and Postgis 1.3.5-1
6. I added the path to the postgresql bin directory to the PATH variable:
PATH C:\Program
Files\PostgreSQL\8.2\bin;%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem
7. I restarted the computer
8. I started AutoCAD Map 3D 2009
9. in the menu you can choose Datei - Mit Daten verbinden (english
translation could be: File - Connect with data)
I expeted that there would be another entry for the FDO PostgreSQL
connection, but there isn't.
Do you have an idea what I made wrong? Is there another location, another
file where I have to make changes?
I found another /fdo/bin-directory where I found some more
OSGeo.FDO.Providers......dlls (like
OSGeo.FDO.Providers.MySQL.Overrides.dll)
C:\Autodesk\AutoCAD_Map3D_2009_German_Win_32bit\x86\Program
Files\Root\FDO\bin
Sorry - I really have no experience with AutoCAD Map3D 2009 and of the FDO
part. But I would like to test the
possibility to edit the PostgreSQL/PostGIS data which is stored in the
PostgreSQL database directly through the fdo connection.
As I read at
* http://trac.osgeo.org/fdo/wiki/FdoPostGISNotes
* or http://lists.osgeo.org/pipermail/fdo-users/2008-November/001325.html
it should generally work with 3.3 fdo PostGIS provider.
Maybe you could help me to manage the problems that I have at the very
beginning.
Thanks in advance
Astrid
 FOSSGIS Konferenz 2009
 17.-19. März 2009 in Hannover
 http://www.fossgis.de/konferenz
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users mailing list
