[fdo-users] [mapguide-users] Compile fdo-3.4.0 on debian lenny
Greg Boone
greg.boone at autodesk.com
Wed Jul 8 10:29:14 EDT 2009
It is hard to determine exactly what the origin of the error would be from your list of steps to reproduce. Can you provide a more expansive set steps that may allow me to understand the build sequence you are using?
Have you followed all the setup steps in:
http://trac.osgeo.org/fdo/browser/trunk/OpenSourceBuild__README.txt
Have you build the Thirdparty directory using the build_thirdparty script?
Please provide a command line of all the commands you execute to build FDO and the setup steps you followed.
Greg
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of leopard01
Sent: Tuesday, July 07, 2009 7:24 PM
To: fdo-users at lists.osgeo.org
Subject: RE: [fdo-users] [mapguide-users] Compile fdo-3.4.0 on debian lenny
Hello Greg,
Im using Debian Lenny Stable too and ..
Someones of my environments variables are:
CC=gcc-4.1
CXX=g++-4.1
FDO=/OpenSource_FDO/Fdo
FDOGDAL=/OpenSource_FDO/Thirdparty/gdal
FDOMYSQL=/OpenSource_FDO/Thirdparty/mysql/rhlinux
FDOODBC=/usr
FDOTHIRDPARTY=/OpenSource_FDO/Thirdparty
FDOUTILITIES=/OpenSource_FDO/Utilities
LD_LIBRARY_PATH=:/usr/local/fdo-3.4.0/lib:/OpenSource_FDO/Thirdparty/ESRI/ArcSDEClient91/Linux/lib
PYTHON_INCLUDE_PATH=/usr/include/python2.4
PYTHON_LIB_PATH=/usr/lib/python2.4
BUT WHAT YOU MEAN? When Just define a valid value for FDOGDAL ??
My variable environment is set: FDOGDAL=/OpenSource_FDO/Thirdparty/gdal
However .. my endless lines after the: /OpenSource_FDO/.build_thirdparty.sh
are ..
make[1]: se sale del directorio `/OpenSource_FDO/Thirdparty/gdal/apps'
make[1]: se ingresa al directorio `/OpenSource_FDO/Thirdparty'
make[1]: *** No hay ninguna regla para construir el objetivo
`apache/xml-xalan/c/lib/libxalan-c.so.17.0', necesario para `all-am'. Alto.
make[1]: se sale del directorio `/OpenSource_FDO/Thirdparty'
make: *** [install-recursive] Error 1
Can you give another advice or another tip for this issue..?
Thanks!
Jan 15, 2009; 01:58pm — by Greg Boone
Yes. Just define a valid value for FDOGDAL and the build should work.
Typically, the FDOGDAL variable is pointed to .../fdo/trunk/Thirdparty/gdal
but you can point it to whatever copy of the GDAL sdk you want to use.
Greg
View this message in context: http://n2.nabble.com/RE%3A--mapguide-users--Compile-fdo-3.4.0-on-debian-lenny-tp2164124p3222500.html
Sent from the FDO Users mailing list archive at Nabble.com.
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
