[fdo-users] Memory problem with ArcSDEProvider92.dll
Dan Stoica
dan.stoica at autodesk.com
Mon Jun 1 15:50:28 EDT 2009
Did you try without the filter? Is it still leaking?
Thanks,
Dan.
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Fuji Deng
Sent: Monday, June 01, 2009 1:31 AM
To: fdo-users at lists.osgeo.org
Subject: Re: [fdo-users] Memory problem with ArcSDEProvider92.dll
Jackie Ng,
Thanks for your suggestion.
After I change the testing codes by following your suggestion. I do the same
testing, there’s still about 60MB memory not released when application
running to “return 0” line.
Is there any advice?
Following are the testing codes:
#include "stdafx.h"
#include "string.h"
#include <Windows.h>
#include "Fdo/Connections/IConnection.h"
#include "Fdo/ClientServices/FeatureAccessManager.h"
#include "Fdo/ClientServices/ConnectionManager.h"
#include "Fdo/Commands/CommandType.h"
#include "Fdo/Commands/ICommand.h"
#include "Fdo/Commands/IFeatureCommand.h"
#include "Fdo/Commands/Feature/ISelect.h"
#include "Geometry/Fgf/Factory.h"
#include "Common/Array.h"
#include "Common/Ptr.h"
void Test()
FdoPtr<FdoConnectionManager> connMgr =
(FdoConnectionManager*)FdoFeatureAccessManager::GetConnectionManager();
FdoPtr<FdoIConnection> connection =
connMgr->CreateConnection(L"OSGeo.ArcSDE");
FdoPtr<FdoFgfGeometryFactory> factory =
FdoFgfGeometryFactory::GetInstance();
connection->SetConnectionString(L"Server=serverIP;Instance=5151;Username=username;Password=password;Datastore=datastore");
FdoConnectionState state = connection->Open();
for (int i = 0; i < 100; i++)
FdoPtr<FdoISelect> command =
(FdoISelect*)connection->CreateCommand(FdoCommandType_Select);
command->SetFeatureClassName(L"TableName");
command->SetFilter(L"Wkt of the specify extent");
FdoPtr<FdoIFeatureReader> reader = command->Execute();
while (reader->ReadNext())
FdoPtr<FdoByteArray> ba = reader->GetGeometry(L"ShapeColumnName");
FdoPtr<FdoIGeometry> geometry = factory->CreateGeometryFromFgf(ba);
int _tmain(int argc, _TCHAR* argv[])
Test();
return 0;
Fuji Deng
Jackie Ng wrote:
> I see two things here:
> 1 - Is there any reason why you have written your own library loader? The
> IConnectionManager already achieves this purpose of obtaining
> FdoIConnection pointers. You can obtain a pointer to the
> IConnectionManager by using
> This code should let you obtain an ArcSDE connection pointer.
> FdoPtr<IConnectionManager> connMgr =
> FdoPtr<FdoIConnection> arcSdeConn =
> 2 - Try wrapping your pointers to Fdo classes within a FdoPtr smart
> pointer template. That will auto-release your pointers when the smart
> pointer goes out of scope.
> - Jackie
> Fuji Deng wrote:
>> Hi,
>> I tried to use ArcSDEProvider92.dll (It’s file version number is
>> 3.4.0.0), I encounted a memory leak problem.
>> The test environment:
>> 1. The application is running in WindowsXP with the latest updates.
>> 2. The application is compiled by Visual Studio 2008 SP1.
>> 3. SQL-Server 2008 And ArcSDE9.2 in Windows 2003 SP2 with almost the
>> latest updates.
>> 4. About ArcSDEProvider92.dll, I test both the file downloaded from
>> website and compile by source codes.
>> There’s the test sample codes at the end of this post.
>> I set 2 breakpoints in the _tmain function, one is at the “for (int i =
>> 0; i < 100; i++)”, the other one is at the “return 0;” The difference of
>> memory usage between these 2 breakpoints is about 60 MB, that means
>> there’re 60 MB memory not released.
>> In each loop, there’re about 300 shapes be read, those shapes are simple
>> polygons, each polygon contains about 5-10 points.
>> I tried to release the all resources in the “for” loop, but it seems
>> there’re still some memory not released.
>> Do I miss something when try to release memory? Or is it the
>> ArcSDEprovider92.dll issue?
>> #include "stdafx.h"
>> #include "string.h"
>> typedef FdoIConnection* (*CreateConnectionProc)();
>> #ifdef _WIN32
>> #ifndef ARCSDEPROVIDER_EXPORTS
>> #define FDOSDE_API __declspec(dllexport)
>> #else
>> #define FDOSDE_API __declspec(dllimport)
>> #endif
>> #endif
>> class ArcSDELoaderLibrary
>> private:
>> HMODULE m_hArcSDE;
>> public:
>> ArcSDELoaderLibrary()
>> m_hArcSDE = NULL;
>> try
>> HMODULE hmod = ::LoadLibraryW(L"sde.dll");
>> if (hmod != NULL)
>> ::FreeLibrary(hmod);
>> m_hArcSDE = ::LoadLibraryW(L"ArcSDEProvider92.dll");
>> // in case load ArcSDEProvider92.dll fails try to load 91
>> if (m_hArcSDE == NULL)
>> m_hArcSDE = ::LoadLibraryW(L"ArcSDEProvider91.dll");
>> else
>> catch(...){}
>> HMODULE GetLibraryHandle()
>> return m_hArcSDE;
>> ~ArcSDELoaderLibrary()
>> try
>> if (m_hArcSDE != NULL)
>> ::FreeLibrary(m_hArcSDE);
>> catch(...){}
>> static ArcSDELoaderLibrary arcSDEloader;
>> // external access to connection for client services
>> extern "C" FDOSDE_API FdoIConnection* CreateConnection ()
>> CreateConnectionProc procCreateConn;
>> HMODULE hArc = arcSDEloader.GetLibraryHandle();
>> if (hArc != NULL)
>> procCreateConn = (CreateConnectionProc)::GetProcAddress (hArc,
>> "CreateConnection");
>> if (procCreateConn != NULL)
>> return procCreateConn();
>> return NULL;
>> FdoIConnection* connection = CreateConnection();
>> FdoString* connectionString =
>> L"Server=serverIP;Instance=5151;Username=username;Password=password;Datastore=datastore";
>> FdoFgfGeometryFactory* factory =
>> connection->SetConnectionString(connectionString);
>> FdoISelect* command =
>> command->SetFilter(L"Shape ENVELOPEINTERSECTS
>> GeomFromText(‘Wkt of the specify extent.')");
>> FdoIFeatureReader* reader = command->Execute();
>> FdoByteArray* ba =
>> FdoIGeometry* geometry =
>> ba->Release();
>> geometry->Release();
>> reader->Release();
>> command->Release();
>> connection->Release();
>> factory->Release();
>> return 0;
View this message in context: http://n2.nabble.com/Memory-problem-with-ArcSDEProvider92.dll-tp3003984p3004741.html
Sent from the FDO Users mailing list archive at Nabble.com.
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
