[fdo-users] Memory problem with ArcSDEProvider92.dll
Fuji Deng
big_willion at 163.com
Tue Jun 2 02:00:52 EDT 2009
Dan,
Thanks for your reply.
I try testing without the filter; it’s still leaking almost the same size
of memory.
After the “Connection->Open()” statement execute, the memory usage is:
“Mem Usage” is 14,524K “VM Size” is 10,660K
When the application runs to “return 0” statement, Following is the memory
usage:
1 - Before remove filter: “Mem Usage” is 76,820K “VM Size” is 72,496K
about 300 records read for one query
2 - After remove filter: “Mem Usage” is 76,840K “VM Size” is
72,600K about 8,000 records read for one query
I do another test also. I keep the filter, and remove the “while
(reader->ReadNext())” and its block. When the application runs to “return 0”
statement, the memory usage is:
“Mem Usage” is 76,956K “VM Size” is 72,632K
Any suggestions?
Thanks!
Fuji Deng
Dan Stoica wrote:
> Hi,
> Did you try without the filter? Is it still leaking?
> Thanks,
> Dan.
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org
> [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Fuji Deng
> Sent: Monday, June 01, 2009 1:31 AM
> To: fdo-users at lists.osgeo.org
> Subject: Re: [fdo-users] Memory problem with ArcSDEProvider92.dll
> Jackie Ng,
> Thanks for your suggestion.
> After I change the testing codes by following your suggestion. I do the
> same
> testing, there’s still about 60MB memory not released when application
> running to “return 0” line.
> Is there any advice?
> Following are the testing codes:
> #include "stdafx.h"
> #include "string.h"
> #include <Windows.h>
> #include "Fdo/Connections/IConnection.h"
> #include "Fdo/ClientServices/FeatureAccessManager.h"
> #include "Fdo/ClientServices/ConnectionManager.h"
> #include "Fdo/Commands/CommandType.h"
> #include "Fdo/Commands/ICommand.h"
> #include "Fdo/Commands/IFeatureCommand.h"
> #include "Fdo/Commands/Feature/ISelect.h"
> #include "Geometry/Fgf/Factory.h"
> #include "Common/Array.h"
> #include "Common/Ptr.h"
> void Test()
> FdoPtr<FdoConnectionManager> connMgr =
> (FdoConnectionManager*)FdoFeatureAccessManager::GetConnectionManager();
> FdoPtr<FdoIConnection> connection =
> connMgr->CreateConnection(L"OSGeo.ArcSDE");
> FdoPtr<FdoFgfGeometryFactory> factory =
> FdoFgfGeometryFactory::GetInstance();
> connection->SetConnectionString(L"Server=serverIP;Instance=5151;Username=username;Password=password;Datastore=datastore");
> FdoConnectionState state = connection->Open();
> for (int i = 0; i < 100; i++)
> FdoPtr<FdoISelect> command =
> (FdoISelect*)connection->CreateCommand(FdoCommandType_Select);
> command->SetFeatureClassName(L"TableName");
> command->SetFilter(L"Wkt of the specify extent");
> FdoPtr<FdoIFeatureReader> reader = command->Execute();
> while (reader->ReadNext())
> FdoPtr<FdoByteArray> ba = reader->GetGeometry(L"ShapeColumnName");
> FdoPtr<FdoIGeometry> geometry = factory->CreateGeometryFromFgf(ba);
> int _tmain(int argc, _TCHAR* argv[])
> Test();
> return 0;
> Fuji Deng
> Jackie Ng wrote:
>> I see two things here:
>> 1 - Is there any reason why you have written your own library loader? The
>> IConnectionManager already achieves this purpose of obtaining
>> FdoIConnection pointers. You can obtain a pointer to the
>> IConnectionManager by using
>> This code should let you obtain an ArcSDE connection pointer.
>> FdoPtr<IConnectionManager> connMgr =
>> FdoPtr<FdoIConnection> arcSdeConn =
>> 2 - Try wrapping your pointers to Fdo classes within a FdoPtr smart
>> pointer template. That will auto-release your pointers when the smart
>> pointer goes out of scope.
>> - Jackie
>> Fuji Deng wrote:
>>> Hi,
>>> I tried to use ArcSDEProvider92.dll (It’s file version number is
>>> 3.4.0.0), I encounted a memory leak problem.
>>> The test environment:
>>> 1. The application is running in WindowsXP with the latest updates.
>>> 2. The application is compiled by Visual Studio 2008 SP1.
>>> 3. SQL-Server 2008 And ArcSDE9.2 in Windows 2003 SP2 with almost the
>>> latest updates.
>>> 4. About ArcSDEProvider92.dll, I test both the file downloaded from
>>> website and compile by source codes.
>>> There’s the test sample codes at the end of this post.
>>> I set 2 breakpoints in the _tmain function, one is at the “for (int i =
>>> 0; i < 100; i++)”, the other one is at the “return 0;” The difference of
>>> memory usage between these 2 breakpoints is about 60 MB, that means
>>> there’re 60 MB memory not released.
>>> In each loop, there’re about 300 shapes be read, those shapes are simple
>>> polygons, each polygon contains about 5-10 points.
>>> I tried to release the all resources in the “for” loop, but it seems
>>> there’re still some memory not released.
>>> Do I miss something when try to release memory? Or is it the
>>> ArcSDEprovider92.dll issue?
>>> #include "stdafx.h"
>>> #include "string.h"
>>> typedef FdoIConnection* (*CreateConnectionProc)();
>>> #ifdef _WIN32
>>> #ifndef ARCSDEPROVIDER_EXPORTS
>>> #define FDOSDE_API __declspec(dllexport)
>>> #else
>>> #define FDOSDE_API __declspec(dllimport)
>>> #endif
>>> #endif
>>> class ArcSDELoaderLibrary
>>> private:
>>> HMODULE m_hArcSDE;
>>> public:
>>> ArcSDELoaderLibrary()
>>> m_hArcSDE = NULL;
>>> try
>>> HMODULE hmod = ::LoadLibraryW(L"sde.dll");
>>> if (hmod != NULL)
>>> ::FreeLibrary(hmod);
>>> m_hArcSDE = ::LoadLibraryW(L"ArcSDEProvider92.dll");
>>> // in case load ArcSDEProvider92.dll fails try to load
>>> 91
>>> if (m_hArcSDE == NULL)
>>> m_hArcSDE = ::LoadLibraryW(L"ArcSDEProvider91.dll");
>>> else
>>> catch(...){}
>>> HMODULE GetLibraryHandle()
>>> return m_hArcSDE;
>>> ~ArcSDELoaderLibrary()
>>> try
>>> if (m_hArcSDE != NULL)
>>> ::FreeLibrary(m_hArcSDE);
>>> catch(...){}
>>> static ArcSDELoaderLibrary arcSDEloader;
>>> // external access to connection for client services
>>> extern "C" FDOSDE_API FdoIConnection* CreateConnection ()
>>> CreateConnectionProc procCreateConn;
>>> HMODULE hArc = arcSDEloader.GetLibraryHandle();
>>> if (hArc != NULL)
>>> procCreateConn = (CreateConnectionProc)::GetProcAddress (hArc,
>>> "CreateConnection");
>>> if (procCreateConn != NULL)
>>> return procCreateConn();
>>> return NULL;
>>> FdoIConnection* connection = CreateConnection();
>>> FdoString* connectionString =
>>> L"Server=serverIP;Instance=5151;Username=username;Password=password;Datastore=datastore";
>>> FdoFgfGeometryFactory* factory =
>>> connection->SetConnectionString(connectionString);
>>> FdoISelect* command =
>>> command->SetFilter(L"Shape ENVELOPEINTERSECTS
>>> GeomFromText(‘Wkt of the specify extent.')");
>>> FdoIFeatureReader* reader = command->Execute();
>>> FdoByteArray* ba =
>>> FdoIGeometry* geometry =
>>> ba->Release();
>>> geometry->Release();
>>> reader->Release();
>>> command->Release();
>>> connection->Release();
>>> factory->Release();
>>> return 0;
> http://n2.nabble.com/Memory-problem-with-ArcSDEProvider92.dll-tp3003984p3004741.html
> Sent from the FDO Users mailing list archive at Nabble.com.
> fdo-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-users
View this message in context: http://n2.nabble.com/Memory-problem-with-ArcSDEProvider92.dll-tp3003984p3010534.html
More information about the fdo-users
