[fdo-users] Upgrading to current version of PostGIS
doggybs
james.slater at keynetix.com
Fri Jun 5 04:23:35 EDT 2009
Hi Mike
I have had similar problems in the past, which i resolved by making sure
that the postgres binaries for the matching postgres server version are
present on the client machine, and added the windows environment variables
'path'.
You may also want to use dependency walker
(http://www.dependencywalker.com/) on the postgis provider dll, to make sure
it is referencing the postgres binary dll for matching server version, an
example dll would be libpq.dll.
Hope this helps
James
Mike Toews wrote:
> Hi,
> I'm using PostGIS on an Ubuntu Hardy 8.04 LTS server, and I've been using
> the FDO PostGIS providers with AutoCAD Map 3D 2008 and 2010 (FDO 3.2 and
> 3.4, respectively) from http://www.geomapgis.com/web/geomap-group/fdo/
> Previously, I was using postgis version 1.3.3 / geos 2.2.3 via apt-get
> http://packages.ubuntu.com/hardy/postgresql-8.3-postgis
> With that setup, my postgis_full_version() SQL command returned:
> POSTGIS="1.3.3" GEOS="2.2.3-CAPI-1.1.1" PROJ="Rel. 4.6.0, 21 Dec 2007"
> USE_STATS
> However, I required an upgrade due to bugs with that version of PostGIS
> and/or geos (namely ST_Buffer). So, I uninstalled the apt-get builds of
> proj, geos and postgis packages, and manually built proj, geos, and
> postgis from source using the current stable versions. Now my
> postgis_full_version() returns:
> POSTGIS="1.3.6" GEOS="3.1.0-CAPI-1.5.0" PROJ="Rel. 4.6.1, 21 August 2008"
> USE_STATS
> The database functions normally, and QGIS can connect, ST_Buffer works,
> etc. However, I cannot connect or use the database as I did before the
> upgrade with the PostGIS provider. When attempting to connect, Map3D 2008
> crashes with an error "AutoCAD cannot continue" an no other message. Map3D
> 2010 doesn't crash, but throws an error/exception "There was a problem
> accessing the connection's schema information."
> So, my question is if the version of PostGIS is important to the FDO
> provider, and if so, what versions are supported? This doesn't have a
> ticket, but I'll start one once I know a bit more info about the versions.
> Thanks,
> -Mike
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
View this message in context: http://n2.nabble.com/Upgrading-to-current-version-of-PostGIS-tp3026919p3029093.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users
