[fdo-users] FDO 3.4.0 - Failed to read identity properties (MS SQL)
miansi AndreiSinelnikov at SierraSystems.com
Mon Jun 8 18:33:32 EDT 2009
Hello,
I am using MapGuide v 2.0.2 and decided to try to upgrade to MapGuide v2.1
Beta1 today.
Everything went fine, but attempt to create/update existing dataconnection
give me long list of errors::
<2009-06-08T16:25:17> 	5560	MapGuide Maestro v1.0.9.39693	::1	Administrator
 Error: An exception occurred in FDO component.
        Item vw_Asset is already in this named collection.
 StackTrace:
  - MgFeatureServiceHandler.ProcessOperation() line 83 file
c:\osgeo\mapguide_21\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
  - MgOpGetIdentityProperties.Execute() line 113 file
c:\osgeo\mapguide_21\mgdev\server\src\services\feature\OpGetIdentityProperties.cpp
  - MgServerDescribeSchema.GetIdentityProperties() line 1683 file
c:\osgeo\mapguide_21\mgdev\server\src\services\feature\ServerDescribeSchema.cpp
  - MgServerDescribeSchema.DescribeFdoSchema() line 204 file
Basically 1 error per table/view in my database. Any idea why it behaves
like that? I've got 3 schemas in the database - dbo, audit and geo. audit
schema has copy of all tables in dbo schema. geo schema has all geospatial
views. Everything worked OK in MG 2.0.2 with FDO 3.3.2
View this message in context: http://n2.nabble.com/FDO-3.4.0---Failed-to-read-identity-properties-%28MS-SQL%29-tp3046089p3046089.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
