[fdo-users] FDO 3.4.0 - Failed to read identity properties (MS SQL)
Jackie Ng jumpinjackie at gmail.com
Mon Jun 8 19:54:41 EDT 2009
Have you tried looking at this data source with FDO Toolbox
(http://fdotoolbox.googlecode.com) to see if you get the same problem?
- Jackie
miansi wrote:
> Hello,
> I am using MapGuide v 2.0.2 and decided to try to upgrade to MapGuide v2.1
> Beta1 today.
> Everything went fine, but attempt to create/update existing dataconnection
> give me long list of errors::
> <2009-06-08T16:25:17> 	5560	MapGuide Maestro v1.0.9.39693	::1
> Administrator
>  Error: An exception occurred in FDO component.
>         Item vw_Asset is already in this named collection.
>  StackTrace:
>   - MgFeatureServiceHandler.ProcessOperation() line 83 file
> c:\osgeo\mapguide_21\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
>   - MgOpGetIdentityProperties.Execute() line 113 file
> c:\osgeo\mapguide_21\mgdev\server\src\services\feature\OpGetIdentityProperties.cpp
>   - MgServerDescribeSchema.GetIdentityProperties() line 1683 file
> c:\osgeo\mapguide_21\mgdev\server\src\services\feature\ServerDescribeSchema.cpp
>   - MgServerDescribeSchema.DescribeFdoSchema() line 204 file
> Basically 1 error per table/view in my database. Any idea why it behaves
> like that? I've got 3 schemas in the database - dbo, audit and geo. audit
> schema has copy of all tables in dbo schema. geo schema has all geospatial
> views. Everything worked OK in MG 2.0.2 with FDO 3.3.2
View this message in context: http://n2.nabble.com/FDO-3.4.0---Failed-to-read-identity-properties-%28MS-SQL%29-tp3046089p3046406.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
