[fdo-users] FDO 3.4.0 - Failed to read identity properties (MS SQL)
miansi AndreiSinelnikov at SierraSystems.com
Mon Jun 8 22:09:21 EDT 2009
Unfortunately this tool not working on x64 platform.
Andrei
[mailto:ml-user+64137-1002950291 at n2.nabble.com]
Sent: Monday, June 08, 2009 5:55 PM
To: Sinelnikov, Andrei
Subject: Re: [fdo-users] FDO 3.4.0 - Failed to read identity properties
(MS SQL)
Have you tried looking at this data source with FDO Toolbox
(http://fdotoolbox.googlecode.com) to see if you get the same problem?
- Jackie
miansi wrote:
Hello,
I am using MapGuide v 2.0.2 and decided to try to upgrade to MapGuide
v2.1 Beta1 today.
Everything went fine, but attempt to create/update existing
dataconnection give me long list of errors::
<2009-06-08T16:25:17> 5560 MapGuide Maestro v1.0.9.39693 ::1
Administrator
 Error: An exception occurred in FDO component.
        Item vw_Asset is already in this named collection.
 StackTrace:
  - MgFeatureServiceHandler.ProcessOperation() line 83 file
c:\osgeo\mapguide_21\mgdev\server\src\services\feature\FeatureServiceHan
dler.cpp
  - MgOpGetIdentityProperties.Execute() line 113 file
c:\osgeo\mapguide_21\mgdev\server\src\services\feature\OpGetIdentityProp
erties.cpp
  - MgServerDescribeSchema.GetIdentityProperties() line 1683 file
c:\osgeo\mapguide_21\mgdev\server\src\services\feature\ServerDescribeSch
ema.cpp
  - MgServerDescribeSchema.DescribeFdoSchema() line 204 file
ema.cpp
Basically 1 error per table/view in my database. Any idea why it behaves
like that? I've got 3 schemas in the database - dbo, audit and geo.
audit schema has copy of all tables in dbo schema. geo schema has all
geospatial views. Everything worked OK in MG 2.0.2 with FDO 3.3.2
This email is a reply to your post @
http://n2.nabble.com/FDO-3.4.0---Failed-to-read-identity-properties-%28M
S-SQL%29-tp3046089p3046406.html
You can reply by email or by visting the link above.
----Notice Regarding Confidentiality----
This email, including any and all attachments, (this "Email") is intended only for the party to whom it is addressed and may contain information that is confidential or privileged.  Sierra Systems Group Inc. and its affiliates accept no responsibility for any loss or damage suffered by any person resulting from any unauthorized use of or reliance upon this Email.  If you are not the intended recipient, you are hereby notified that any dissemination, copying or other use of this Email is prohibited.  Please notify us of the error in communication by return email and destroy all copies of this Email.  Thank you.
View this message in context: http://n2.nabble.com/FDO-3.4.0---Failed-to-read-identity-properties-%28MS-SQL%29-tp3046089p3046861.html
Sent from the FDO Users mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20090608/e25991aa/attachment.html
More information about the fdo-users mailing list
