[fdo-users] FDO 3.4.0 - Failed to read identity properties (MS
SQL)
miansi
AndreiSinelnikov at SierraSystems.com
Tue Jun 9 01:14:16 EDT 2009
OK. I think this deserves a ticket :-)
After further investigation I discovered that FDO do not like database
objects with the same name to be part of different schemas.
i.e. if you have table dbo.Asset - it will throw an exception if you also
have table audit.Asset or geo.Asset.
Although I cannot confirm as of right now if it is an exception or just a
warning, because Maestro give you an option to save dataconnection.
Andrei
Jackie Ng wrote:
> Have you tried looking at this data source with FDO Toolbox
> (http://fdotoolbox.googlecode.com) to see if you get the same problem?
> - Jackie
View this message in context: http://n2.nabble.com/FDO-3.4.0---Failed-to-read-identity-properties-%28MS-SQL%29-tp3046089p3047496.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users
