[fdo-users] AutoCAD Map3D and Oracle FDO Issues
Mike Toews
mwtoews at sfu.ca
Thu Jun 11 21:19:47 EDT 2009
Tony,
I think I had a similar problem, although I'm using Map3D 2008/2010 with
a PostgreSQL/PostGIS database. The issue was Map3D was creating and
sending a [single] POLYGON object to a MULTIPOLYGON column, which it
shouldn't, since the column has check constraints to ensure they are all
MULTIPOLYGON geometries. I fixed it by writing a simple BEFORE INSERT OR
UPDATE trigger to check and correct if the polygon is a multi object.
I'm no pro with Oracle spatial, but the guts of my PL/pgSQL (with
PostGIS) trigger function look somthing like this:
IF ST_GeometryType(NEW.geometry) IN('POLYGON','LINESTRING') THEN
NEW.geometry := ST_Multi(NEW.geometry);
END IF;
I think most of this is portable to your situation, except that
ST_GeometryType() returns different values. I'm not sure if there is a
generic ST_Multi() function, but there are similar casts that you can use.
Hope this helps,
-Mike
Tony wrote:
> i am using fdo (autodesk) as well as used king fdo for getting the CAD data
> write to oracle.
> here is the whole story : i have a polygon shape file i have used FDO2FDO to
> create oracle table , I want to edit some of geometries in AutoCADmap 3D as
> well as i want to add new polygons there.
> the issue: i have createa a closed polygon in autocadmap that have Arc and
> line and i was trying to write this to the above created table. i am
> getting error saying that geometry type does not match,
> after reading the logs i found out that though my Oracle table has mpolygon
> geometry type i can not write and polygon with Arc(true arc) in it.
> any idea how to solve this issue. i have wote to autodesk and still wating
> to get the answer. i wrote to king fdo no reply yet ...
> please let me know how to solve this
More information about the fdo-users
