[fdo-users] AutoCAD Map3D and Oracle FDO Issues
Tony techswami at hotmail.com
Fri Jun 12 01:58:34 EDT 2009
Mike
thanks in millions for answer. could you tell me how to implement the
trigger from autocad insert.
i am new to autocad .
thanks
tony
Mike Toews wrote:
> Tony,
> I think I had a similar problem, although I'm using Map3D 2008/2010 with
> a PostgreSQL/PostGIS database. The issue was Map3D was creating and
> sending a [single] POLYGON object to a MULTIPOLYGON column, which it
> shouldn't, since the column has check constraints to ensure they are all
> MULTIPOLYGON geometries. I fixed it by writing a simple BEFORE INSERT OR
> UPDATE trigger to check and correct if the polygon is a multi object.
> I'm no pro with Oracle spatial, but the guts of my PL/pgSQL (with
> PostGIS) trigger function look somthing like this:
>   IF ST_GeometryType(NEW.geometry) IN('POLYGON','LINESTRING') THEN
>     NEW.geometry := ST_Multi(NEW.geometry);
>   END IF;
> I think most of this is portable to your situation, except that
> ST_GeometryType() returns different values. I'm not sure if there is a
> generic ST_Multi() function, but there are similar casts that you can use.
> Hope this helps,
> -Mike
> Tony wrote:
>> i am using fdo (autodesk) as well as used king fdo for getting the CAD
>> data
>> write to oracle.
>> here is the whole story : i have a polygon shape file i have used FDO2FDO
>> to
>> create  oracle table , I want to edit some of geometries in AutoCADmap 3D
>> as
>> well as i want to add new polygons there.
>> the issue:  i have createa a closed polygon in autocadmap that have Arc
>> and
>> line and i was trying to write this to the above created table.  i am
>> getting error saying  that geometry type does not match,
>> after reading the logs i found out that though my Oracle table has
>> mpolygon
>> geometry type i can not write  and polygon with Arc(true arc) in it.
>> any idea how to solve this issue. i have wote to autodesk and still
>> wating
>> to get the answer. i wrote to  king fdo no reply yet ...
>> please let me know how to solve this
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
View this message in context: http://n2.nabble.com/AutoCAD-Map3D-and-Oracle-FDO-Issues-tp3065246p3066137.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users mailing list
