[fdo-users] Manipulation of FDO-enabled RDBMSes without using FDO
Jackie Ng
jumpinjackie at gmail.com
Mon Jun 15 04:13:51 EDT 2009
Hi All,
Is it safe to perform normal CRUD operations on a FDO-enabled rdbms using
standard DML statements (SELECT, UPDATE, INSERT, DELETE)?
The idea is we have a MySQL db that is initially prepared with FDO, but we
want to maintain the data afterwards (using standard SQL queries) without
having to use FDO.
- Jackie
View this message in context: http://n2.nabble.com/Manipulation-of-FDO-enabled-RDBMSes-without-using-FDO-tp3079066p3079066.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users
