[fdo-users] Manipulation of FDO-enabled RDBMSes without using FDO
Orest Halustchak
orest.halustchak at autodesk.com
Mon Jun 15 11:33:17 EDT 2009
Hi Jackie,
That should be OK.
Orest.
-----Original Message-----
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Monday, June 15, 2009 4:14 AM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] Manipulation of FDO-enabled RDBMSes without using FDO
Hi All,
Is it safe to perform normal CRUD operations on a FDO-enabled rdbms using
standard DML statements (SELECT, UPDATE, INSERT, DELETE)?
The idea is we have a MySQL db that is initially prepared with FDO, but we
want to maintain the data afterwards (using standard SQL queries) without
having to use FDO.
- Jackie
View this message in context: http://n2.nabble.com/Manipulation-of-FDO-enabled-RDBMSes-without-using-FDO-tp3079066p3079066.html
Sent from the FDO Users mailing list archive at Nabble.com.
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
