[fdo-users] PostGIS and Map 3D 2010 autoincrement problems
Mike Toews
mwtoews at sfu.ca
Mon Jun 22 19:52:45 EDT 2009
David,
Yikes. I've been demoing Map3D 2010 for the past few weeks to see if we
want to upgrade from 2008, and I can reproduce the same behavior you
describe in 2010. This behavior is new to me, since it is not an issue
with 2008 (the serial appears as 0 in the table, as you described, until
it is checked-in and refreshed).
To add details, the error response from 2010 when trying to check-in a
new feature:
<Error code="200" type="5" dispensation="3" sId="2"
occurrence="1">Feature was not saved in the target feature
source.<Parameters>
<Parameter classId="0" position="0">
<Message>2=Invalid property value name 'gid'.
</Message>
<SQL></SQL>
</Parameter>
<Message>1=Failed to execute Fdo command.
</Message>
<SQL></SQL>
</Parameter>
<Message>Failed to insert feature.</Message>
<SQL></SQL>
</Parameter>
<Message>FdoPostGIS:mytable (), Rev# <0></Message>
<SQL></SQL>
</Parameter></Parameters>
<Entry code="1" type="15" sId="3" occurrence="1">Failed to save some
features.</Entry>
<Entry code="1" type="15" sId="4" occurrence="1">Failed to save edit
set.</Entry>
</Error>
In QGIS and other programs, the default value for a serial (integer)
that is shown in the property before insert/commit is
"nextval('mytable_gid_seq'::regclass)", which might explain the error
message "Invalid property value name 'gid'", since it appears as a
string, not an integer in this form.
I tried fixing this with some trigger functions within the database, but
whatever I've tried I can't seem to make a workaround. The best I can do
is raise some exception in a before trigger, which shows up in the error
message in AutoCAD, but making a trigger that sets "NEW.gid :=
nextval('mytable_gid_seq'::regclass);" still throws the error shown above.
Is this an issue with FDO or with AutoCAD Map3D 2010?
-Mike
David Anderson wrote:
> I have been trying to setup Map 3D 2010 to access a PostGIS database
> that has a feature set to auto increment the primary key. When trying
> to create a new feature, Map 3D complains about the gid being invalid
> because it tries to add it as 0. Map 3D won’t let me change the value
> because it is controlling it. If I check in the feature, close the
> drawing, reopen the drawing Map 3D shows the feature even though it
> was saying it couldn’t be added. I have tried with various
> combinations of PostgreSQL 8.2 & 8.3 and PostGIS 1.3.4-1.3.6 with the
> same results.
> Is anybody successfully using Map 3D with the auto increment setting?
> Does this only work with a certain data type? Any help would be
> greatly appreciated.
> QGIS and uDig both access the database properly and can add features
> so the database is working in that respect.
> Thanks,
> David
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
