[fdo-users] RE: Map 3D with FDO 3.4
Greg Boone
greg.boone at autodesk.com
Thu Mar 5 14:37:03 EST 2009
No, FDO 3.4.0 will be compatible with Map 3D 2010. It is not compatible with Map 3D 2009. Continue to use the FDO 3.3.x stream for 2009.
Greg
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of David Anderson
Sent: Thursday, March 05, 2009 2:17 PM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] Map 3D with FDO 3.4
I just tried to install the 3.4.0 RC1 version of FDO with Civil/Map 3D 2009 and AutoCAD reports that it failed to load connection control for provider. Will 3.4.0 work with Map 3D 2009? 3.3.2 works just fine.
Thanks for your help.
David Anderson, P.E.
Donnell & Allred, Inc.
908 Big Horn Ave
P.O. Box 638
Worland, WY 82401
307-347-8276
307-347-8277 fax
da at donnellandallred.com<mailto:da at donnellandallred.com>
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20090305/4ea53da8/attachment.html
More information about the fdo-users
