[fdo-users] RE: Map 3D with FDO 3.4
Greg Boone greg.boone at autodesk.com
Thu Mar 5 16:38:06 EST 2009
Options:
In the $MAPINSTALL\FDO\Bin directory...
1)      Open providers.xml and look at the FDO version numbers it references
2)      Select Fdo.dll, right-click, properties, version number
Greg
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Brad Nesom
Sent: Thursday, March 05, 2009 4:34 PM
To: FDO Users Mail List
Subject: RE: [fdo-users] RE: Map 3D with FDO 3.4
Is there a way in map 2009 to find out what version fdo it is using?
Thanks
To: fdo-users at lists.osgeo.org
Date: Thu, 5 Mar 2009 11:37:03 -0800
Subject: [fdo-users] RE: Map 3D with FDO 3.4
No, FDO 3.4.0 will be compatible with Map 3D 2010. It is not compatible with Map 3D 2009. Continue to use the FDO 3.3.x stream for 2009.
Greg
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of David Anderson
Sent: Thursday, March 05, 2009 2:17 PM
Subject: [fdo-users] Map 3D with FDO 3.4
I just tried to install the 3.4.0 RC1 version of FDO with Civil/Map 3D 2009 and AutoCAD reports that it failed to load connection control for provider.  Will 3.4.0 work with Map 3D 2009?  3.3.2 works just fine.
Thanks for your help.
David Anderson, P.E.
Donnell & Allred, Inc.
908 Big Horn Ave
P.O. Box 638
Worland, WY  82401
307-347-8276
307-347-8277 fax
da at donnellandallred.com<mailto:da at donnellandallred.com>
Windows Live(tm) Groups: Create an online spot for your favorite groups to meet. Check it out.<http://windowslive.com/online/groups?ocid=TXT_TAGLM_WL_groups_032009>
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20090305/c1f8bfaa/attachment-0001.html
More information about the fdo-users mailing list
