[fdo-users] Problem with map2009 fdo 3.3.2
Brad Nesom kidsmake6 at msn.com
Fri Mar 6 00:09:13 EST 2009
Using Map3d 2009 with the installed 3.3.0 trying to connect to esri personal
gdb with ogr. I get the connection to complete but always have to
edit/override the coord system. Then after adding to map get the message
"failed to cache features" 2 "geometry is null". View log looks like this.
<?xml version="1.0" ?>
- <Map3dErrorLog xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:noNamespaceSchemaLocation="AcMap3dErrorLog.xsd">
- <Session user="ws21" start="3/5/2009 10:30:38 PM" document="Drawing1.dwg">
- <Error code="1" type="15" dispensation="2" sId="2" occurrence="1">
  Failed to cache features.
  <Entry code="1" type="15" sId="3" occurrence="1">Geometry is null.</Entry>
  <Entry code="1" type="15" sId="4" occurrence="1">Failed to cache
features.</Entry>
  <Entry code="1" type="15" sId="5" occurrence="1">Geometry is null.</Entry>
  <Entry code="1" type="15" sId="6" occurrence="1">Failed to cache
features.</Entry>
  <Entry code="1" type="15" sId="7" occurrence="1">Geometry is null.</Entry>
  <Entry code="1" type="15" sId="8" occurrence="1">Failed to cache
features.</Entry>
  <Entry code="1" type="15" sId="9" occurrence="1">Geometry is null.</Entry>
  <Entry code="1" type="15" sId="10" occurrence="1">Failed to cache
features.</Entry>
  <Entry code="1" type="15" sId="11" occurrence="1">Geometry is
null.</Entry>
  <Entry code="1" type="15" sId="12" occurrence="1">Failed to cache
features.</Entry>
  <Entry code="1" type="15" sId="13" occurrence="1">Geometry is
null.</Entry>
  <Entry code="1" type="15" sId="14" occurrence="1">Failed to cache
features.</Entry>
  <Entry code="1" type="15" sId="15" occurrence="1">Geometry is
null.</Entry>
  </Error>
- <Error code="1" type="15" dispensation="1" sId="16" occurrence="1">
  <Entry code="1" type="15" sId="17" occurrence="1">Geometry is
null.</Entry>
  </Error>
  </Session>
  </Map3dErrorLog>
If I use fdo 3.3.2 to connect to the same data. I get the same messages with
this as a log file.
- <Session user="ws21" start="3/5/2009 10:58:26 PM" document="Drawing1.dwg">
  </Error>
  </Session>
  </Map3dErrorLog>
Can someone help me get this to work?
Thanks
Brad
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20090305/4665bd47/attachment.html
More information about the fdo-users mailing list
