[fdo-users] RE: ESRI File Geodatabases
Traian Stanev
traian.stanev at autodesk.com
Fri Mar 6 18:54:34 EST 2009
Which OGRProvider.dll are you using -- the one I posted at the URL below?
http://13-9.com/OGRProvider-3.3.0.zip
Traian
________________________________________
From: fdo-users-bounces at lists.osgeo.org [fdo-users-bounces at lists.osgeo.org] On Behalf Of Brad Nesom [kidsmake6 at msn.com]
Sent: Friday, March 06, 2009 5:51 PM
To: 'FDO Users Mail List'
Subject: RE: [fdo-users] RE: ESRI File Geodatabases
Traian,
I am unable to accomplish even read only of the MDB in 3.3.0 or 3.3.2. Also the documentation shows that is it read/write.
http://fdo.osgeo.org/OSProviderOverviews.html
OSGeo FDO Provider for OGR<http://fdo.osgeo.org/fdoogr/index.html>
OGR is a open source library. Read and write access is provided to vector data from the OGR library
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Traian Stanev
Sent: Friday, March 06, 2009 9:10 AM
Subject: [fdo-users] RE: ESRI File Geodatabases
Hi David,
If you are talking about the personal geodatabase, that’s in MDB format – you can read those with the OGR provider, in both 3.3 and 3.4. Note that support is read only.
Traian
From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of David Anderson
Sent: Thursday, March 05, 2009 3:14 PM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] ESRI File Geodatabases
Does 3.3 or 3.4 support the ESRI file geodatabase?
Thanks,
David Anderson, P.E.
Donnell & Allred, Inc.
908 Big Horn Ave
P.O. Box 638
Worland, WY 82401
307-347-8276
307-347-8277 fax
da at donnellandallred.com<mailto:da at donnellandallred.com>
More information about the fdo-users
