[fdo-users] RE: ESRI File Geodatabases
Brad Nesom kidsmake6 at msn.com
Mon Mar 9 08:29:53 EDT 2009
No, the 3.3.0 version I am using is the shipped with and installed with
autodesk map 3d 2009.
At this time I have the 3.3.2 version installe from the fdo downloads...
http://fdo.osgeo.org/content/fdo-332-downloads
Windows SDK
The following tar files contains the Windows (32 bit) Managed and Unmanaged
FDO SDK files, including binaries, libraries and header files.
fdosdk-win32-3.3.2.tar.gz
-----Original Message-----
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Traian Stanev
Sent: Friday, March 06, 2009 5:55 PM
To: FDO Users Mail List
Subject: RE: [fdo-users] RE: ESRI File Geodatabases
Which OGRProvider.dll are you using -- the one I posted at the URL below?
  http://13-9.com/OGRProvider-3.3.0.zip
Traian
________________________________________
From: fdo-users-bounces at lists.osgeo.org [fdo-users-bounces at lists.osgeo.org]
On Behalf Of Brad Nesom [kidsmake6 at msn.com]
Sent: Friday, March 06, 2009 5:51 PM
To: 'FDO Users Mail List'
Traian,
  I am unable to accomplish even read only of the MDB in 3.3.0 or 3.3.2.
Also the documentation shows that is it read/write.
http://fdo.osgeo.org/OSProviderOverviews.html
OSGeo FDO Provider for OGR<http://fdo.osgeo.org/fdoogr/index.html>
OGR is a open source library. Read and write access is provided to vector
data from the OGR library
Sent: Friday, March 06, 2009 9:10 AM
Subject: [fdo-users] RE: ESRI File Geodatabases
Hi David,
If you are talking about the personal geodatabase, that's in MDB format -
you can read those with the OGR provider, in both 3.3 and 3.4. Note that
support is read only.
Traian
[mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of David Anderson
Sent: Thursday, March 05, 2009 3:14 PM
To: fdo-users at lists.osgeo.org
Subject: [fdo-users] ESRI File Geodatabases
Does 3.3 or 3.4 support the ESRI file geodatabase?
Thanks,
David Anderson, P.E.
Donnell & Allred, Inc.
908 Big Horn Ave
P.O. Box 638
Worland, WY  82401
307-347-8276
307-347-8277 fax
da at donnellandallred.com<mailto:da at donnellandallred.com>
fdo-users mailing list
http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users mailing list
