[fdo-users] Postgis Schemas
doggybs
james.slater at keynetix.com
Tue Mar 17 12:05:16 EDT 2009
I am using the POSTGIS FDO 3.3.2, connected to a postgis table that is not
in the public schema for the database.
In the postgis FDO connection properties I set the DataStore to be
myNewSchema.
Everything connects fine, and I am able to create the layer.
The Data also displays fine on the map.
But I am not able to select any of the items or get a tooltip to display.
If I setup exactly the same table in the public scheme selection and
tooltips work fine. I have a primary key setup and I have added all the
correct indexes in the correct order.
Does anyone else have any experience of this, or know if this is a known
bug?
Thanks
View this message in context: http://n2.nabble.com/Postgis-Schemas-tp2492275p2492275.html
Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users
