[fdo-users] Network share SHP access
Olivier Doucet
olvd at yahoo.fr
Fri Nov 13 07:35:37 EST 2009
Hi Jackie,
Thank you for your help!
I was indeed trying with the UNC notation and using a mapped drive solves the problem.
However I would prefer - if possible - not to use mapped drives.
Is the UNC notation just not supported by the provider or are there other conditions to meet to make it work?
Olivier
De : Jackie Ng <jumpinjackie at gmail.com>
À : fdo-users at lists.osgeo.org
Envoyé le : Ven 13 Novembre 2009, 5 h 00 min 22 s
Objet : Re: [fdo-users] Network share SHP access
Are you using UNC notation for your file paths (eg. \\server\share\file.shp)?
You might get better success by mapping that network share as a drive, and
then use a path to that mapped drive.
- Jackie
Olivier Doucet-5 wrote:
> Hi Folks,
> I am new to FDO technology and trying unsuccessfully to read shapefiles
> located on a Windows network share.
> I am using the .NET C# API with ASP.NET 2.0 (that I am discovering too),
> and the version 3.4 of OSGeo.SHP.
> After googling a bit, it seems that it could be a permission issue though
> I cannot get it to work even with no permission restriction on the share.
> Has anyone faced this issue already? Is it any possible to access SHP on
> network drives? If yes, a hint would be welcome!
> Thank you.
> Olivier
> fdo-users mailing list
> http://lists.osgeo.org/mailman/listinfo/fdo-users
View this message in context: http://n2.nabble.com/Network-share-SHP-access-tp3996720p3997275.html
Sent from the FDO Users mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20091113/cf806530/attachment.html
More information about the fdo-users
