[fdo-users] arcsde sdk
Dejan Gregor
dejan.gregor at gmail.com
Mon Nov 30 09:56:15 EST 2009
Yes, it should work. ESRI technology (e.g. ArcSDE SDK) is always
backward compatible within any version of ESRI Geodatabase 9.x, so
also ArcSDE SDK 9.2 know about ArcSDE SDK 9.1, but not the other way
around. There might be some slight changes in additional
functionalities - please check the Release notes (usually in a form of
a PDF) on the installation CD or ask ESRI or ESRI Distributor to
provide it.
Good luck!
Dejan
On Mon, Nov 30, 2009 at 15:48, Chris Erickson <chris at cartopac.com> wrote:
> Yes, I understand this. I was asking a question RE: compatability. Does the 9.2 sdk work with SDE 9.1?
> chris erickson
> developer
> 970.493.9500 x 191
> 970.482.1485 (fax)
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-bounces at lists.osgeo.org] On Behalf Of Dejan Gregor
> Sent: Wednesday, November 25, 2009 7:54 AM
> To: fdo-users at lists.osgeo.org
> Subject: Re: [fdo-users] arcsde sdk
> Dear Chris,
> the ESRI ArcSDE SDK comes with the ArcSDE installation discs. It is under
> license terms.
> Kind regards,
> Dejan Gregor
> Chris Erickson-2 wrote:
>> To use the sde provider, do I have to have the sdk that matches the
>> version of sde, or can I use a newer one? (I.e. are they backward
>> compatible?) It seems that arcgis desktop can connect to anything older
>> than the version you have installed, with only 1 version of the sdk....
>> chris erickson
>> developer
>> cartopac field solutions
>> 970.493.9500 x 191
>> fdo-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/fdo-users
> __
> Dejan Gregor, MSc
> GISc Researcher and Consultant
> http://www.linkedin.com/in/dgregor
> View this message in context: http://n2.nabble.com/arcsde-sdk-tp4042955p4065376.html
> Sent from the FDO Users mailing list archive at Nabble.com.
More information about the fdo-users
