[fdo-users] FDO Compile error (libxalan-c)
kernel_panic sudoaptgetinstalld00d3 at gmail.com
Tue Oct 6 01:08:45 EDT 2009
Hi, John
When you say
> "The First(FDO) stage requires for gdl, sdf, shp, ogr some fixes in
> xml-xalan - looks like something you get for free with visual studio
> has to be spelled out in gcc (#include <cstring>) in a number of
> places in the code. Also in the gdal sub-build there some issues with
> passing environment variables between shell scripts - a well known
> trap which can cause grief - I did a hack to get it to work - I do not
> remember what the optimal solution is as it was a long time ago."
What kind of stuff are you talking about, regarding to visual studio, gcc
and the passing environment variables issues?
I mean, you dont have to tell me "do this, do that and done", but if you can
give me a hint (or anyone else :p) on what to look for and where, I might
get a greater insight on this, and perhaps, find a solution by narrowing the
possible causes of this problem.
Heh, for a "well known" problem, solution remains "unknown", because this is
the second time I read that someone has fixed this, cant dont remember how
:p:p
Thanks for the reply!
URL: http://lists.osgeo.org/pipermail/fdo-users/attachments/20091006/dea51ea6/attachment.html
More information about the fdo-users mailing list
