[fdo-users] FDO Compile error (libxalan-c)
Traian Stanev
traian.stanev at autodesk.com
Thu Oct 8 12:33:47 EDT 2009
I did not use the internal cppunit. I just used the one that Ubuntu installs. So try that...
I did not need to use root until I called make install at the end.
Traian
> -----Original Message-----
> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-
> bounces at lists.osgeo.org] On Behalf Of kernel_panic
> Sent: Thursday, October 08, 2009 12:25 PM
> To: FDO Users Mail List
> Subject: Re: [fdo-users] FDO Compile error (libxalan-c)
> > Did you use the "internal" cppunit library or the one that comes by doing
> > apt-get -- i.e. what did you pass to cmake on the command line when you
> > first called it?
> Yes, I used the internal cppunit library, as instructed in the cmake
> readme file.
> BTW, I forgot to post the command line that I used :p :
> cmake /opt/fdo-3.5_D032/ -DINTERNAL_CPPUNIT=TRUE -DWITH_GDAL=TRUE
> -DWITH_GENERICRDBMS=TRUE -DWITH_OGR=TRUE -DWITH_POSTGIS=TRUE
> -DWITH_SDF=TRUE -DWITH_SHP=TRUE -DWITH_WFS=TRUE -DWITH_WMS=TRUE
> (I was already root)
> If I run make (not cmake) for a second time, this is what I get:
> [ 0%] Built target mkcatdefs
> [ 3%] Built target sqlite3fdo
> [ 3%] Built target FileToHdr
> [ 3%] Built target SchemaFromInternal
> [ 3%] Built target McToMsf
> [ 3%] Built target FDOMessage
> [ 3%] Built target ProcessedFiles
> [ 20%] Built target FDO
> [ 20%] Built target XsdInstallPaths
> [ 20%] Built target Internal_Cppunit
> [ 22%] Built target UnitTest
> [ 23%] Built target ProvidersCommon
> [ 24%] Built target TestCommon
> [ 29%] Built target ExpressionEngine
> [ 31%] Built target FdoOws
> [ 31%] Built target SMMessage
> [ 32%] Built target SmPhRd
> [ 32%] Built target SmOverrides
> [ 34%] Built target SmLogicalPhysical
> [ 34%] Built target SmPhCfg
> [ 34%] Built target SmPhMt
> [ 35%] Built target SmPhRb
> [ 41%] Built target SmPhysical
> [ 41%] Built target SchemaMgr
> [ 42%] Built target SQLiteInterface
> [ 42%] Built target fdordbmsmsg
> [ 47%] Built target FdoRdbms
> [ 48%] Built target Gdbi
> [ 48%] Built target LTManager
> [ 49%] Built target LockManager
> [ 49%] Built target geometry_fgf
> [ 51%] Built target mysqldr
> [ 51%] Built target FdoRdbmsMySQL_Fdo
> [ 51%] Built target FdoRdbmsMySQL_SchemaMgr_Lp
> [ 53%] Built target FdoRdbmsMySQL_SchemaMgr_Ov
> [ 54%] Built target FdoRdbmsMySQL_SchemaMgr
> [ 55%] Built target FdoRdbmsMySQL_SchemaMgr_Ph_Rd
> [ 56%] Built target FdoRdbmsMySQL_SchemaMgr_Ph
> [ 59%] Built target rdbi
> [ 60%] Built target SmLpGrd
> [ 61%] Built target SchemaMgr_OV
> [ 61%] Built target SmGrd
> [ 61%] Built target SmPhCfgGrd
> [ 61%] Built target SmPhRdGrd
> [ 62%] Built target SmPhGrd
> [ 63%] Built target genericrdbms_util
> [ 63%] Built target FdoMySQL
> [ 66%] Built target FdoODBCDriver
> [ 66%] Built target FdoRdbmsODBC_SchemaMgr
> [ 67%] Built target FdoRdbmsODBC_Fdo
> [ 67%] Built target FdoRdbmsODBC_SchemaMgr_Lp
> [ 68%] Built target FdoRdbmsODBC_SchemaMgr_Ov
> [ 70%] Built target FdoRdbmsODBC_SchemaMgr_Ph
> [ 70%] Built target FdoODBC
> [ 70%] Built target PostGisMessage
> [ 71%] Built target PostGISOverrides
> [ 74%] Built target PostGISProvider
> [ 74%] Built target ShpMessage
> [ 74%] Built target SHPOverrides
> [ 76%] Built target SHPRead
> [ 77%] Built target SHPSpatialIndex
> [ 80%] Built target SHPProvider
> Linking CXX executable UnitTest
> And after that, "the puke" comes on...
> > The SHP provider in trunk as compiled by cmake works fine for me on Ubuntu
> > 9.04 64 bit. I assume 32 bit works as well, since that's better tested
> than
> > the 64 bit. For reading SHP files you can also use the OGR provider, which
> > also works fine for me on 9.04 64 bit.
> If the OGR provider can deal with SHP files, then, why is there a SHP
> provider? :P Are there any limitations? :p
> > ________________________________________
> > From: fdo-users-bounces at lists.osgeo.org [fdo-users-bounces at lists.osgeo.org]
> > On Behalf Of kernel_panic [sudoaptgetinstalld00d3 at gmail.com]
> > Sent: Wednesday, October 07, 2009 7:55 PM
> > Well, I tried what you suggested about using cmake instead of automake.
> > I followed instructions from Cmake_readme, but encountered a few
> > problems regarding to GDAL libraries being linked by OGR, GDAL and WMS
> > that werent found. I fixed that by editing the cmake files on ogr and
> > gdal/src/provider/, adding libgdal1.5.0.so to each linked library
> > section, like this:
> > target_link_libraries( GRFPProvider
> > GRFPOverrides
> > ProvidersCommon
> > FDO
> > libgdal1.5.0.so
> > After that, the cmake command ran with no errors, but when I ran the
> > make command I get A LOT of this:
> CMakeFiles/SHPUnitTest.dir/FdoExpressionFunctionTest.cpp.o:(.data.rel.ro._ZT
> VN7CppUnit10TestCallerI25FdoExpressionFunctionTestNS_19NoExceptionExpectedEE
> E[vtable
> > for CppUnit::TestCaller<FdoExpressionFunctionTest,
> > CppUnit::NoExceptionExpected>]+0x34): undefined reference to
> > `CppUnit::Test::checkIsValidIndex(int) const'
> E[vtable
> > CppUnit::NoExceptionExpected>]+0x38): undefined reference to
> > `CppUnit::TestLeaf::doGetChildTestAt(int) const'
> IN7CppUnit10TestCallerI25FdoExpressionFunctionTestNS_19NoExceptionExpectedEE
> E[typeinfo
> > CppUnit::NoExceptionExpected>]+0x8): undefined reference to `typeinfo
> > for CppUnit::TestCase'
> > ../../../../Utilities/TestCommon/libTestCommon.so.3.5.0: undefined
> > reference to `CppUnit::Test::findTestPath(CppUnit::Test const*,
> > CppUnit::TestPath&) const'
> > reference to `CppUnit::Test::findTestPath(std::basic_string<char,
> > std::char_traits<char>, std::allocator<char> > const&,
> > reference to `CppUnit::Message::Message(std::basic_string<char,
> > std::basic_string<char, std::char_traits<char>, std::allocator<char> >
> > const&)'
> > reference to `CppUnit::Asserter::fail(CppUnit::Message const&,
> > CppUnit::SourceLine const&)'
> > const&, std::basic_string<char, std::char_traits<char>,
> > std::allocator<char> > const&)'
> > reference to `CppUnit::Asserter::failIf(bool, CppUnit::Message const&,
> > reference to `CppUnit::Test::resolveTestPath(std::basic_string<char,
> > std::char_traits<char>, std::allocator<char> > const&) const'
> > collect2: ld devolvió el estado de salida 1
> > make[2]: *** [Providers/SHP/Src/UnitTest/UnitTest] Error 1
> > make[1]: *** [Providers/SHP/Src/UnitTest/CMakeFiles/SHPUnitTest.dir/all]
> > Error 2
> > make: *** [all] Error 2
> > As long as the terminal screen can "remember" :p
> > Did it happen to you? (both) What do you think the problem may be with SHP?
> > :P
> fdo-users mailing list
> fdo-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
