[fdo-users] FDO Compile error (libxalan-c)
kernel_panic
sudoaptgetinstalld00d3 at gmail.com
Thu Oct 8 13:32:10 EDT 2009
@ Traian:
I used ubuntu's cpp instead of the internal, now I didnt have the
error listed earlier, but I got this new one:
[ 91%] Built target GDALUnitTest
Scanning dependencies of target OGRProvider
[ 91%] Building CXX object
Providers/OGR/CMakeFiles/OGRProvider.dir/OgrFdoUtil.cpp.o
Providers/OGR/CMakeFiles/OGRProvider.dir/OgrProvider.cpp.o
/opt/fdo-3.5_D032/Providers/OGR/OgrProvider.cpp: In member function
‘FdoIFeatureReader* OgrConnection::Insert(FdoIdentifier*,
FdoPropertyValueCollection*)’:
/opt/fdo-3.5_D032/Providers/OGR/OgrProvider.cpp:585: aviso: el formato
‘%d’ espera el tipo ‘int’, pero el argumento 4 es de tipo ‘long int’
Providers/OGR/CMakeFiles/OGRProvider.dir/ProjConverter.cpp.o
Linking CXX shared library libOGRProvider.so
[ 91%] Built target OGRProvider
Scanning dependencies of target SDFMessage
[ 91%] Generating SDFMessage.h ...
../../../../Thirdparty/linux/mkcatdefs/src/mkcatdefs: SDFMessage_msg.h created
cat: /opt/fdo-3.5_D032/Providers/SDF/Src/Message/SDFMessageStatic.h:
No existe el fichero ó directorio
make[2]: *** [Providers/SDF/Src/Message/Inc/SDFMessage.h] Error 1
make[1]: *** [Providers/SDF/Src/Message/CMakeFiles/SDFMessage.dir/all] Error 2
make: *** [all] Error 2
The commandline was the same, except for the internal cpp part.
@ Greg Boone:
How do I disable them? :p
2009/10/8, Traian Stanev <traian.stanev at autodesk.com>:
> I did not use the internal cppunit. I just used the one that Ubuntu
> installs. So try that...
> I did not need to use root until I called make install at the end.
> Traian
>> -----Original Message-----
>> From: fdo-users-bounces at lists.osgeo.org [mailto:fdo-users-
>> bounces at lists.osgeo.org] On Behalf Of kernel_panic
>> Sent: Thursday, October 08, 2009 12:25 PM
>> To: FDO Users Mail List
>> Subject: Re: [fdo-users] FDO Compile error (libxalan-c)
>> > Did you use the "internal" cppunit library or the one that comes by
>> > doing
>> > apt-get -- i.e. what did you pass to cmake on the command line when you
>> > first called it?
>> Yes, I used the internal cppunit library, as instructed in the cmake
>> readme file.
>> BTW, I forgot to post the command line that I used :p :
>> cmake /opt/fdo-3.5_D032/ -DINTERNAL_CPPUNIT=TRUE -DWITH_GDAL=TRUE
>> -DWITH_GENERICRDBMS=TRUE -DWITH_OGR=TRUE -DWITH_POSTGIS=TRUE
>> -DWITH_SDF=TRUE -DWITH_SHP=TRUE -DWITH_WFS=TRUE -DWITH_WMS=TRUE
>> (I was already root)
>> If I run make (not cmake) for a second time, this is what I get:
>> [ 0%] Built target mkcatdefs
>> [ 3%] Built target sqlite3fdo
>> [ 3%] Built target FileToHdr
>> [ 3%] Built target SchemaFromInternal
>> [ 3%] Built target McToMsf
>> [ 3%] Built target FDOMessage
>> [ 3%] Built target ProcessedFiles
>> [ 20%] Built target FDO
>> [ 20%] Built target XsdInstallPaths
>> [ 20%] Built target Internal_Cppunit
>> [ 22%] Built target UnitTest
>> [ 23%] Built target ProvidersCommon
>> [ 24%] Built target TestCommon
>> [ 29%] Built target ExpressionEngine
>> [ 31%] Built target FdoOws
>> [ 31%] Built target SMMessage
>> [ 32%] Built target SmPhRd
>> [ 32%] Built target SmOverrides
>> [ 34%] Built target SmLogicalPhysical
>> [ 34%] Built target SmPhCfg
>> [ 34%] Built target SmPhMt
>> [ 35%] Built target SmPhRb
>> [ 41%] Built target SmPhysical
>> [ 41%] Built target SchemaMgr
>> [ 42%] Built target SQLiteInterface
>> [ 42%] Built target fdordbmsmsg
>> [ 47%] Built target FdoRdbms
>> [ 48%] Built target Gdbi
>> [ 48%] Built target LTManager
>> [ 49%] Built target LockManager
>> [ 49%] Built target geometry_fgf
>> [ 51%] Built target mysqldr
>> [ 51%] Built target FdoRdbmsMySQL_Fdo
>> [ 51%] Built target FdoRdbmsMySQL_SchemaMgr_Lp
>> [ 53%] Built target FdoRdbmsMySQL_SchemaMgr_Ov
>> [ 54%] Built target FdoRdbmsMySQL_SchemaMgr
>> [ 55%] Built target FdoRdbmsMySQL_SchemaMgr_Ph_Rd
>> [ 56%] Built target FdoRdbmsMySQL_SchemaMgr_Ph
>> [ 59%] Built target rdbi
>> [ 60%] Built target SmLpGrd
>> [ 61%] Built target SchemaMgr_OV
>> [ 61%] Built target SmGrd
>> [ 61%] Built target SmPhCfgGrd
>> [ 61%] Built target SmPhRdGrd
>> [ 62%] Built target SmPhGrd
>> [ 63%] Built target genericrdbms_util
>> [ 63%] Built target FdoMySQL
>> [ 66%] Built target FdoODBCDriver
>> [ 66%] Built target FdoRdbmsODBC_SchemaMgr
>> [ 67%] Built target FdoRdbmsODBC_Fdo
>> [ 67%] Built target FdoRdbmsODBC_SchemaMgr_Lp
>> [ 68%] Built target FdoRdbmsODBC_SchemaMgr_Ov
>> [ 70%] Built target FdoRdbmsODBC_SchemaMgr_Ph
>> [ 70%] Built target FdoODBC
>> [ 70%] Built target PostGisMessage
>> [ 71%] Built target PostGISOverrides
>> [ 74%] Built target PostGISProvider
>> [ 74%] Built target ShpMessage
>> [ 74%] Built target SHPOverrides
>> [ 76%] Built target SHPRead
>> [ 77%] Built target SHPSpatialIndex
>> [ 80%] Built target SHPProvider
>> Linking CXX executable UnitTest
>> And after that, "the puke" comes on...
>> > The SHP provider in trunk as compiled by cmake works fine for me on
>> > Ubuntu
>> > 9.04 64 bit. I assume 32 bit works as well, since that's better tested
>> than
>> > the 64 bit. For reading SHP files you can also use the OGR provider,
>> > which
>> > also works fine for me on 9.04 64 bit.
>> If the OGR provider can deal with SHP files, then, why is there a SHP
>> provider? :P Are there any limitations? :p
>> > ________________________________________
>> > [fdo-users-bounces at lists.osgeo.org]
>> > On Behalf Of kernel_panic [sudoaptgetinstalld00d3 at gmail.com]
>> > Sent: Wednesday, October 07, 2009 7:55 PM
>> > Well, I tried what you suggested about using cmake instead of automake.
>> > I followed instructions from Cmake_readme, but encountered a few
>> > problems regarding to GDAL libraries being linked by OGR, GDAL and WMS
>> > that werent found. I fixed that by editing the cmake files on ogr and
>> > gdal/src/provider/, adding libgdal1.5.0.so to each linked library
>> > section, like this:
>> > target_link_libraries( GRFPProvider
>> > GRFPOverrides
>> > ProvidersCommon
>> > FDO
>> > libgdal1.5.0.so
>> > After that, the cmake command ran with no errors, but when I ran the
>> > make command I get A LOT of this:
>> CMakeFiles/SHPUnitTest.dir/FdoExpressionFunctionTest.cpp.o:(.data.rel.ro._ZT
>> VN7CppUnit10TestCallerI25FdoExpressionFunctionTestNS_19NoExceptionExpectedEE
>> E[vtable
>> > for CppUnit::TestCaller<FdoExpressionFunctionTest,
>> > CppUnit::NoExceptionExpected>]+0x34): undefined reference to
>> > `CppUnit::Test::checkIsValidIndex(int) const'
>> E[vtable
>> > CppUnit::NoExceptionExpected>]+0x38): undefined reference to
>> > `CppUnit::TestLeaf::doGetChildTestAt(int) const'
>> IN7CppUnit10TestCallerI25FdoExpressionFunctionTestNS_19NoExceptionExpectedEE
>> E[typeinfo
>> > CppUnit::NoExceptionExpected>]+0x8): undefined reference to `typeinfo
>> > for CppUnit::TestCase'
>> > ../../../../Utilities/TestCommon/libTestCommon.so.3.5.0: undefined
>> > reference to `CppUnit::Test::findTestPath(CppUnit::Test const*,
>> > CppUnit::TestPath&) const'
>> > reference to `CppUnit::Test::findTestPath(std::basic_string<char,
>> > std::char_traits<char>, std::allocator<char> > const&,
>> > reference to `CppUnit::Message::Message(std::basic_string<char,
>> > std::basic_string<char, std::char_traits<char>, std::allocator<char> >
>> > const&)'
>> > reference to `CppUnit::Asserter::fail(CppUnit::Message const&,
>> > CppUnit::SourceLine const&)'
>> > const&, std::basic_string<char, std::char_traits<char>,
>> > std::allocator<char> > const&)'
>> > reference to `CppUnit::Asserter::failIf(bool, CppUnit::Message const&,
>> > reference to `CppUnit::Test::resolveTestPath(std::basic_string<char,
>> > std::char_traits<char>, std::allocator<char> > const&) const'
>> > collect2: ld devolvió el estado de salida 1
>> > make[2]: *** [Providers/SHP/Src/UnitTest/UnitTest] Error 1
>> > make[1]: *** [Providers/SHP/Src/UnitTest/CMakeFiles/SHPUnitTest.dir/all]
>> > Error 2
>> > As long as the terminal screen can "remember" :p
>> > Did it happen to you? (both) What do you think the problem may be with
>> > SHP?
>> > :P
>> fdo-users mailing list
>> fdo-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/fdo-users
More information about the fdo-users
